Hello all! I'm new to this but rather puter savy. The problem I have is I've actually customized another custom template but now the product categories move down the page when viewing products. I tried fixed position (really cool looking but stays on top when the screen is not expanded) and many other items with no luck. It almost looks like even if it is set to absolute it is moved when you click on a product. I'm using version 1.3.8 and it is a recent install. Take a look at the following URL and you will see what I'm talking about. Also, the text about the Big Linked has got to go but I can't seem to remove it. I know this is alot and do apprecite your time. Thanks soooo muck!!!!:
http://www.boatersontop.com/Store/in...products_id=74
Also the text shows up here..
http://www.boatersontop.com/Store/in...index&cPath=22
