Hi All,
I have a feedback module i would like to install but i am not very good with Zencart and when it asks me to add some code to the <head> and the <body> tags i don't know where i should put it.
Asher
Hi All,
Asher
What kind of code?
The header needs some javascript and the body some html/css
Put the javascript inside an appropriately-named file in the prescribed folder, according to this FAQ article, and Zen Cart will automatically load the code for you. No need to touch template files.
http://www.zen-cart.com/wiki/index.p...s_-_Javascript
what about the body?
anyone know?
What page are you wanting to put it on?
What's the code you're supposed to put in the body?
I need to put the following code into the <head> section of the home page:
This was a request from a company I'm using to do Google Analytics work for me. I didn't know how to convert this into a .js file. If someone can convert this to a form that can be used in a .js file, I can take care of it. But if not, is there a way to add this to the <head> section of the home page?Code:<script type="text/javascript"> __compete_code = 'dcafd398df98a9f097d0384b52d77295'; (function () { var s = document.createElement('script'), e = document.getElementsByTagName('script')[0]; s.src = (document.location.protocol.toLowerCase() === 'https:' ? 'https:' : 'http:') + '//c.compete.com/bootstrap/dcafd398df98a9f097d0384b52d77295/bootstrap.js'; s.type = 'text/javascript'; s.async = true; if (e) { e.parentNode.insertBefore(s, e); } }()); </script>
One quick way to do it would be to dump all that code into a new file and upload it to your site as: /includes/modules/pages/index/jscript_compete-com.php
If it truly needs to *only* appear on the home page, put these two lines in the file first, and then add your code between these two lines:Code:<?php if ($this_is_home_page) {?> put your code here <?php } ?>
Thanks, Dr Byte. I don't think it will hurt to have that code be available on other pages as well, but I don't know how to convert my code so that it can reside in a *.js file. I can't just copy it as is, can I? Or is it OK just as it is? I think I would at least take out the <script> tags, right?
Sorry, I'm not too savvy with java script.
