* Common Template - tpl_main_page.php
* Governs the overall layout of an entire page<br />
* Normally consisting of a header, left side column. center column. right side column and footer<br />
* For customizing, this file can be copied to /templates/your_template_dir/pagename<br />
* example: to override the privacy page<br />
* - make a directory /templates/my_template/privacy<br />
* - copy /templates/templates_defaults/common/tpl_main_page.php to /templates/my_template/privacy/tpl_main_page.php<br />
* <br />
* to override the global settings and turn off columns un-comment the lines below for the correct column to turn off<br />
* to turn off the header and/or footer uncomment the lines below<br />
* Note: header can be disabled in the tpl_header.php<br />
* Note: footer can be disabled in the tpl_footer.php<br />
* <br />
* $flag_disable_header = true;<br />
* $flag_disable_left = true;<br />
* $flag_disable_right = true;<br />
* $flag_disable_footer = true;<br />
* <br />
* // example to not display right column on main page when Always Show Categories is OFF<br />
* <br />
* if ($current_page_base == 'index' and $cPath == '') {<br />
* }<br />
* <br />
* example to not display right column on main page when Always Show Categories is ON and set to categories_id 3<br />
* <br />
* if ($current_page_base == 'index' and $cPath == '' or $cPath == '3') {<br />
* }<br />
* @package templateSystem
* @copyright Copyright 2003-2007 Zen Cart Development Team
* @version $Id: tpl_main_page.php 7085 2007-09-22 04:56:31Z ajeh $
// the following IF statement can be duplicated/modified as needed to set additional flags
if (in_array($current_page_base,explode(",",'list_pages_to_skip_all_right_sideboxes_on_here,separated_by_commas,and_no_spaces')) ) {
$header_template = 'tpl_header.php';
$footer_template = 'tpl_footer.php';
$left_column_file = 'column_left.php';
$right_column_file = 'column_right.php';
$body_id = ($this_is_home_page) ? 'indexHome' : str_replace('_', '', $_GET['main_page']);
<body id="<?php echo $body_id . 'Body'; ?>"<?php if($zv_onload !='') echo ' onload="'.$zv_onload.'"'; ?>>
if (SHOW_BANNERS_GROUP_SET1 != '' && $banner = zen_banner_exists('dynamic', SHOW_BANNERS_GROUP_SET1)) {
<div id="bannerOne" class="banners"><?php echo zen_display_banner('static', $banner); ?></div>
<div id="mainWrapper">
* prepares and displays header output
if (CUSTOMERS_APPROVAL_AUTHORIZATION == 1 && CUSTOMERS_AUTHORIZATION_HEADER_OFF == 'true' and ($_SESSION['customers_authorization'] != 0 or $_SESSION['customer_id'] == '')) {
require($template->get_template_dir('tpl_header.php',DIR_WS_TEMPLATE, $current_page_base,'common'). '/tpl_header.php');?>
<table width="100%" border="0" cellspacing="0" cellpadding="0" id="contentMainWrapper">
<tr>
if (COLUMN_LEFT_STATUS == 0 || (CUSTOMERS_APPROVAL == '1' and $_SESSION['customer_id'] == '') || (CUSTOMERS_APPROVAL_AUTHORIZATION == 1 && CUSTOMERS_AUTHORIZATION_COLUMN_LEFT_OFF == 'true' and ($_SESSION['customers_authorization'] != 0 or $_SESSION['customer_id'] == ''))) {
// global disable of column_left
if (!isset($flag_disable_left) || !$flag_disable_left) {
<td id="navColumnOne" class="columnLeft" style="width: <?php echo COLUMN_WIDTH_LEFT; ?>">
* prepares and displays left column sideboxes
<div id="navColumnOneWrapper" style="width: <?php echo BOX_WIDTH_LEFT; ?>"><?php require(DIR_WS_MODULES . zen_get_module_directory('column_left.php')); ?></div></td>
<td valign="top">
<!-- bof breadcrumb -->
<?php if (DEFINE_BREADCRUMB_STATUS == '1' || (DEFINE_BREADCRUMB_STATUS == '2' && !$this_is_home_page) ) { ?>
<div id="navBreadCrumb"><?php echo $breadcrumb->trail(BREAD_CRUMBS_SEPARATOR); ?></div>
<?php } ?>
<!-- eof breadcrumb -->
if (SHOW_BANNERS_GROUP_SET3 != '' && $banner = zen_banner_exists('dynamic', SHOW_BANNERS_GROUP_SET3)) {
<div id="bannerThree" class="banners"><?php echo zen_display_banner('static', $banner); ?></div>
<!-- bof upload alerts -->
<?php if ($messageStack->size('upload') > 0) echo $messageStack->output('upload'); ?>
<!-- eof upload alerts -->
* prepares and displays center column
require($body_code); ?>
if (SHOW_BANNERS_GROUP_SET4 != '' && $banner = zen_banner_exists('dynamic', SHOW_BANNERS_GROUP_SET4)) {
<div id="bannerFour" class="banners"><?php echo zen_display_banner('static', $banner); ?></div>
?></td>
//if (COLUMN_RIGHT_STATUS == 0 || (CUSTOMERS_APPROVAL == '1' and $_SESSION['customer_id'] == '') || (CUSTOMERS_APPROVAL_AUTHORIZATION == 1 && CUSTOMERS_AUTHORIZATION_COLUMN_RIGHT_OFF == 'true' && $_SESSION['customers_authorization'] != 0)) {
if (COLUMN_RIGHT_STATUS == 0 || (CUSTOMERS_APPROVAL == '1' and $_SESSION['customer_id'] == '') || (CUSTOMERS_APPROVAL_AUTHORIZATION == 1 && CUSTOMERS_AUTHORIZATION_COLUMN_RIGHT_OFF == 'true' and ($_SESSION['customers_authorization'] != 0 or $_SESSION['customer_id'] == ''))) {
// global disable of column_right
if (!isset($flag_disable_right) || !$flag_disable_right) {
<td id="navColumnTwo" class="columnRight" style="width: <?php echo COLUMN_WIDTH_RIGHT; ?>">
* prepares and displays right column sideboxes
<div id="navColumnTwoWrapper" style="width: <?php echo BOX_WIDTH_RIGHT; ?>"><?php require(DIR_WS_MODULES . zen_get_module_directory('column_right.php')); ?></div></td>
</tr>
</table>
* prepares and displays footer output
if (CUSTOMERS_APPROVAL_AUTHORIZATION == 1 && CUSTOMERS_AUTHORIZATION_FOOTER_OFF == 'true' and ($_SESSION['customers_authorization'] != 0 or $_SESSION['customer_id'] == '')) {
require($template->get_template_dir('tpl_footer.php',DIR_WS_TEMPLATE, $current_page_base,'common'). '/tpl_footer.php');
<!--bof- parse time display -->
if (DISPLAY_PAGE_PARSE_TIME == 'true') {
<div class="smallText center">Parse Time: <?php echo $parse_time; ?> - Number of Queries: <?php echo $db->queryCount(); ?> - Query Time: <?php echo $db->queryTime(); ?></div>
<!--eof- parse time display -->
<!--bof- banner #6 display -->
if (SHOW_BANNERS_GROUP_SET6 != '' && $banner = zen_banner_exists('dynamic', SHOW_BANNERS_GROUP_SET6)) {
<div id="bannerSix" class="banners"><?php echo zen_display_banner('static', $banner); ?></div>
<!--eof- banner #6 display -->
require($template->get_template_dir('.php',DIR_WS_TEMPLATE, $current_page_base,'google_analytics') . '/google_analytics.php');
</body>
