Results 1 to 1 of 1
Threaded View
    Aug 2008
    Default tpl_module_attributes.php - need help figuring out what is what
    Zen Cart - Version 1.3.8a
    Added the following plugin: Stocks By Attribute
    Site has been visually customized and I have used the proper template override system so none of the main files have been edited.
    I want to move the following items around using div tags and css but I can't figure out what controls what on this php file.
    I have two drop down menus (size / color)
    The color drop down has image attributes and I want to move the images to the bottom of the page and then arrange the options as follows:
    Please Choose:
    Color [ ] ....................................................Add to Cart button
    Size [ ]............................................................will go
    Quantity [1]..........................................................over here
    Color Option Images:
    line up the attribute color thumbnails under here.
    If someone could just give me a hint as to what php string controls what element I think that I can do the rest myself.
    Thank you in advance for any help. I have read a bunch of threads on this topic but haven't found one that breaks down this particular file into display elements.
    Also - not sure how to get the "quantity" away from the add to cart. I will go back and look at the product_info_display.php code to see if that is even possible. If not I can turn it off since the cart allows you to choose how many you want there.
    Thanks again,
    Tanya
    www.finehandwear.com/store
    Last edited by tanyaslogos; 16 Feb 2010 at 07:47 PM. Reason: to add dots to move cart button over
  1. Need Help Figuring Out Features In This Algozone Template
    By JusMeJim in forum Templates, Stylesheets, Page Layout
    Last Post: 11 Feb 2013, 01:57 AM
  2. Need help figuring out errors
    By nolsowski in forum General Questions
    Last Post: 23 Jan 2011, 12:56 AM
  3. Need help figuring out what I deleted
    By susanshropshire in forum Templates, Stylesheets, Page Layout
    Last Post: 13 Jun 2009, 02:31 AM
  4. What software is best for figuring out how zen cart works.
    By birdoasis in forum General Questions
    Last Post: 12 Apr 2007, 07:58 PM
