Results 1 to 10 of 11
    Mar 2010
    Default Shipping per unit/weight not calculating for more than one item
    I have set up my shipping to use the Per Item/Unit Weight and I have it set to use the amount in the weight for the shipping cost.
    For Ex:
    I have the weight of an item at 10.00 - it will charge $10 shipping per item.
    The problem is when someone tries to purchase more than one item, it is supposed to add 10.00 per item but it's not. How can I fix this??
    My site is http://www.upm75.com
    Mar 2010
    Default Re: Shipping per unit/weight not calculating for more than one item
    TFYI his is where I got the idea to do it that way...
    https://www.zen-cart.com/tutorials/i...hp?article=208
    Were you able to fix this?
    I add to cart and my shipping appears to be the quantity * products_weight * unit rate ...
    Mar 2010
    Not fixed yet....
    If you try to order 6 of the UPM 75 pitching machines, the shipping should be $120 ($20 per unit x 6 = $120 total) When you go through the checkout process it makes the shipping $185????
    Could you check your settings in the Configuration ... Shipping/Packaging ...
    Set the values for:
    Maximum Weight to 5000
    Both Tare Weights to 0:0
    Mar 2010
    It is all set that way and still does it.....
    I get the right calculations of 6 x 20 = 120 ... not sure what to tell you ...
    Mar 2010
    Are you going through the entire checkout process (up to where you would confirm the order). The shipping estimator tells you the correct amount, it's when I go through paypal to pay and when I get to the page where I would confirm my order is when it tells the wrong amount.
    Does this happen on the Zen Cart shop or on the PayPal Page?
    I go to the:
    checkout_shipping $120.00
    checkout_payment $120.00
    checkout_confirmation $120.00
    Mar 2010
    I'm not sure? I think it might be the Paypal. When I go to check out I click "checkout" and then it goes to where you click the "Paypal Express Checkout" and then you sign into you Paypal, you go to next and it comes back to Zencart and you would click "confirm" to finish the payment. That is when the shipping is incorrect.
  1. v139h Per Weight Unit shipping does not work!
    By n_t_r in forum Built-in Shipping and Payment Modules
    Last Post: 21 Feb 2012, 06:45 PM
  2. Cheaper shipping for more than one item
    By axeladam in forum Built-in Shipping and Payment Modules
    Last Post: 18 May 2011, 02:57 PM
  3. Shipping Break on more than One Item?
    By gabstero in forum Addon Shipping Modules
    Last Post: 13 Dec 2010, 05:24 PM
  4. How do i insert more than one image for one item?
    By len47811 in forum General Questions
    Last Post: 23 Aug 2010, 06:41 AM
  5. more than one attributes per item
    By Makoshark in forum General Questions
    Last Post: 6 Mar 2010, 09:02 PM
