Results 1 to 2 of 2
    Oct 2006
    Worcester, MA
    Default Problem cloning table shipping
    I've successfully cloned table shipping modules in the past but now I'm running into a problem and I'm not sure of the cause or the solution.
    When I try to install the newly cloned module, I get this error:
    1062 Duplicate entry 'MODULE_SHIPPING_TABLE_COST' for key 2
    in:
    [insert into configuration (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, set_function, date_added) values ('Shipping Table', 'MODULE_SHIPPING_TABLE_COST', '25:8.50,50:5.50,10000:0.00', 'The shipping cost is based on the total cost or weight of items or count of the items. Example: 25:8.50,50:5.50,etc.. Up to 25 charge 8.50, from there to 50 charge 5.50, etc
    You can end the last amount as 10000:7% to charge 7% of the Order Total', '6', '0', 'zen_cfg_textarea(', now())]
    Any clues? When I hit the back button the new module seems to be partially installed. It shows the Remove button and the edit button but the rest of the information seems missing. If I hit Edit, there are just a bunch of blank fields with no labels or anything. I've tried removing and reinstalling but get the same results.
    Of course my client needs the new shipping rates right away, which is probably why I'm having trouble
    Oct 2006
    Worcester, MA
    Default Re: Problem cloning table shipping
    Doh! Solved my own problem by looking more closely at the error message. I missed one replace in the cloning.
    Problem with trying to go too fast, I guess!
  1. Tips on cloning Table Rate shipping module
    By shirster in forum Built-in Shipping and Payment Modules
    Last Post: 2 Dec 2010, 10:41 AM
  2. Help cloning table module
    By nwagoner in forum Built-in Shipping and Payment Modules
    Last Post: 26 Sep 2008, 06:01 PM
  3. cloning table rate crushed
    By deadheat1 in forum Built-in Shipping and Payment Modules
    Last Post: 16 Jul 2008, 02:01 AM
  4. Cloning Table Rate mode
    By sylsau in forum Addon Shipping Modules
    Last Post: 16 Dec 2006, 02:16 AM
  5. cloning the shipping module - table
    By drmad in forum Built-in Shipping and Payment Modules
    Last Post: 20 Oct 2006, 08:11 PM
