Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
    Jan 2010
    Default Problem renaming admin folder - v1.38a
    Hi there,
    I have tried to do the admin patch (change admin name) on zen cart 1.38a and after this I can not get in the admin.
    I changed the file permissions as suggested but I think it is not properly changing back somehow.
    Any idea's on the best fix for this..... fairly new to zen cart so not too good at this
    any help appreciated
    Apr 2007
    Herts. UK
    Default Re: admin patch? zen cart 1.38a
    Are you getting any error messages? If there are no errors appearing it could be a cookie issue, clear your cookies and try again.
    Regards,
    Christian.
    Jan 2010
    Hi there,
    I just get this message here
    Page Not Found
    Custom 404 Error Page with Site Map Sample Text ...
    I have a /shop folder so it is like this /shop/****** << new admin name
    Apr 2007
    Herts. UK
    Quote Originally Posted by Jay76 View Post
    Most likely you have missed something in your /shop/newadmindir/includes/configure.php file.
    Regards,
    Christian.
    Jan 2010
    cant see how as added the new folder name to the configure php and changed the name on the admin main folder? .... strange
    Oct 2009
    Smack in the Middle
    Are you sure you were in admin/includes/configure.php and not just includes/configure.php? (just taking a shot here, not sure how you made the changes)
    As far as file permissions go, you may need to change them in cPanel as opposed to ftp.
    Good Luck, hope it all comes together.
    Dalton
    Skin that 'un pilgrim, and I'll bring ya' another.
    Running 1.3.9h with a few mods here
    Jan 2010
    Hi Dalton,
    I followed these instructions >> https://www.zen-cart.com/tutorials/index.php?article=33
    Also my web guy had a go and failed too? is there something else that needs to be done extra?
    Defo the Admin > Includes folder that this was done on
    Jan 2010
    I even copied and pasted the new admin folder name to prevent mistakes.
    Does this have anything to do because I have a folder called shop then admin so looks like this .... shop>admin
    Also noticed a admin.php file? any changes needed for this
    Apr 2007
    Herts. UK
    No changes need to be made to the admin.php file just the configure.php file.
    If you can post the contents of your configure.php file here between PHP tags then someone might be able to spot if there is a problem. Just blank out the sensitive parts with XXXs.
    Regards,
    Christian.
    Jan 2010
    I have just edited these area's as advised;
    define('DIR_WS_ADMIN', '/shop/**********/');
    define('DIR_WS_CATALOG', '/shop/');
    define('DIR_WS_HTTPS_ADMIN', '/shop/**********/');
    define('DIR_WS_HTTPS_CATALOG', '/shop/');
    and;
    define('DIR_FS_ADMIN', '/home/********/public_html/shop/**********/');
    define('DIR_FS_CATALOG', '/home/********/public_html/shop/');
    I have used astrix as I dont want to post this fully on the site for obvious reasons
  1. Problem with renaming Admin folder
    By TzuLady in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 21 Apr 2010, 06:19 AM
  2. Renaming ADMIN folder?
    By kenny724 in forum Templates, Stylesheets, Page Layout
    Last Post: 13 Feb 2010, 05:02 PM
  3. renaming admin folder
    By pcdesigns in forum Templates, Stylesheets, Page Layout
    Last Post: 10 Jun 2008, 08:41 PM
