Results 1 to 5 of 5
    Nov 2009
    Default Help with product options please
    hi i am new to zen cart would like to no if this is possible and how to implement it ., i want to set up website for foam conversion, i want customers to be able input length depth width of a piece of foam and the zen cart to calculate the total cost formula would be length x width x depth / 144 x 0.4
    any suggestions i would be more than grateful
    thanks tony
    Apr 2004
    UK
    Default Re: Help with product options please
    Example using Rope as product...tutorials/faq link top of this page should also help
    http://www.dezinashop.com/demo/index...roducts_id=154
    Nov 2009
    thanks for your help , but nothing in faq or your site that resolves the problem..
    This requires "Dependant" attributes to do correctly and ZenCart does not have support for dependant attributes
    A work around you might find acceptable would be to divide up your product offerings into your stock max dimensions or standard dimentions where you maximize use.
    Could be widths of upto with a max length
    24inch
    36inch
    48inch
    etc
    Then add attricutes for depths
    Results in more individual products but workable
    Nov 2009
    thanks for your help , did not want to introduce any script that might upset the the zen core . i thought i might have to do it that way
    thanks again black belt
  1. Problem with shipping options! Please Help!!
    By sakush100 in forum Built-in Shipping and Payment Modules
    Last Post: 27 Sep 2011, 02:42 PM
  2. Need help with product prices + options
    By rternier in forum Setting Up Categories, Products, Attributes
    Last Post: 25 Jul 2008, 06:17 PM
  3. A Few Product Display Options Have Me Stuck... Help Please
    By DPM in forum Templates, Stylesheets, Page Layout
    Last Post: 9 Apr 2008, 09:55 AM
  4. help with product set-up with options (customer chooses quantity of option)
    By airtime in forum Setting Up Categories, Products, Attributes
    Last Post: 13 Mar 2007, 05:06 PM
  5. CSS help with product options
    By Rowan_H in forum Templates, Stylesheets, Page Layout
    Last Post: 4 Nov 2006, 06:28 AM
