Im trying to style a box surrounding the individual product areas set up using the column_layout_grid contribution to create a 4 across display. For reference see
http://smallfish-design.com/tape/ind...=index&cPath=1
I'm trying to create some space between these boxes, and it appears that the width is set someplace (i cant find) and so when I add a margin dimension to the containing div, the widths increase and the 4th box wraps onto the second line.
I'm not sure if I'm in need of a css solution or need to modify a module but I'm stuck where I am so any thoughts in either direction would be appreciated.
Steve
