    May 2009
    Default images and flash issue in IE
    Hi.
    I'm using 1.3.8
    In FF and Chrome the site displays fine, while in IE the flash (in the header) and all images, but one, don't show, having the white box instead.
    Site is:
    www.nativo.biz/shop
    Jun 2005
    Cumbria, UK
    Default Re: images and flash issue in IE
    If you are using a 64-bit browser, then Flash will not work. There is (as yet) no adobe plugin for 64-bit browsers.
    That's one reason I don't ever use flash... another is it takes too long to load most flash files, and finally they tend to be distractions - taking the customer's attention off the product info.
    20 years a Zencart User
    May 2009
    Thanks, but I'm afraid that's not the case, I'm using 32 bit.
    And more than the flash (it's a white space anyway), the main problem are the images ...
    Jun 2005
    Cumbria, UK
    But your CUSTOMERS may use 64-bit...
    Flash should ONLY be used if it enhances a product and encourages a sale.
    Using flash (or any dancing animation) just for the sake of it is pointless. They can be (and usually are) more of a distraction than an enhancement.
    May 2009
    I'm sorry, I may have not been very clear:
    the biggest issue is the images that don't display, I can live with the flash not displaying.
    Besides that, the 32/64 bit os is NOT the case, if *I* don't see them while using the 32, means the issue is there regardless of that.
    May 2009
    I upgraded to 1.39b, and still have the images not displaying, any ideas please?
  1. v139h Issue with images, possible solutions and turnaround
    By isd88 in forum General Questions
    Last Post: 28 Aug 2012, 04:01 PM
  2. some help please, salemaker issue and ssl images
    By odysseus in forum Setting Up Specials and SaleMaker
    Last Post: 21 Oct 2009, 02:01 PM
  3. Flash issue.. css flyout menu hides under flash..
    By Muzz in forum Templates, Stylesheets, Page Layout
    Last Post: 8 Sep 2009, 06:41 AM
  4. Are my images and flash showing?
    By wtashby in forum General Questions
    Last Post: 3 Oct 2008, 01:14 PM
  5. Adding products and images issue
    By teager in forum Setting Up Categories, Products, Attributes
    Last Post: 11 Jul 2008, 07:42 AM
