    Apr 2010
    Default Need help for .htaccess redirect
    I made the redirection several days ago, but It seems that It doesn't work. The htaccess info as follow:
    Options +FollowSymlinks
    RewriteEngine on
    rewritecond %{http_host} ^reddoublehappiness.com [nc]
    rewriterule ^(.*)$ http://www.reddoublehappiness.com/$1 [r=301,nc]
    rewritecond %{http_host} ^www.chinesedecorationshop.com [nc]
    It is correct?
    Oct 2006
    Alberta, Canada
    Default Re: Need help for .htaccess redirect
    RewriteEngine ON
    ## Rewrite / Redirect all requests
    ## from: http://reddoublehappiness.com
    ## to: http://www.reddoublehappiness.com
    RewriteCond %{HTTP_HOST} ^reddoublehappiness.com(.*)
    RewriteRule ^(.*)$ http://www.reddoublehappiness.com/$1 [R=301,L]
    As for "www . chinesedecorationshop . com" better to do a URL redirect from within your Registrar account.
    Mar 2010
    UK
    Neither of the above will redirect requests for the non-www hostname of chinesedecorationshop.com nor for www.reddoublehappiness.com:80 or other appended port numbers.
    How to fix this, depends on whether other domain names point to this server, or not.
    If there are no other domain names that serve content, and all alternative hostnames need to redirect, this is the simplest way:
    RewriteEngine on
    RewriteCond %{HTTP_HOST} !^www\.reddoublehappiness\.com$
    RewriteRule (.*) http://www.reddoublehappiness.com/$1 [R=301,L]
    Remember to escape literal periods in patterns, and don't play fast and loose with the syntax.
    Apr 2010
    Yes, I want to redirect reddoublehappiness.com to www.reddoublehappiness.com and I also want to redirect www.chinesedecorationshop.com to www.reddoublehappiness.com, how to do this?
    Oct 2006
    Alberta, Canada
    You have been given two examples of redirecting reddoublehappiness.com.
    For chinesedecorationshop.com, it is best to redirect it from within your Registrar account.
    Mar 2010
    UK
    Do you also want to redirect chinesedecorationshop.com too?
  1. v154 Using htaccess to redirect legacy links. Need help!
    By Feznizzle in forum General Questions
    Last Post: 5 Jan 2016, 03:11 AM
  2. .htaccess redirect help for a coming soon URL
    By limelites in forum General Questions
    Last Post: 17 Jul 2011, 02:32 AM
  3. I need help with .htaccess redirect!
    By htmt in forum Basic Configuration
    Last Post: 26 Apr 2011, 02:53 PM
  4. Replies: 3
    Last Post: 11 Apr 2010, 07:57 AM
  5. Need to redirect, can't find .htaccess - help?
    By Unicorn in forum General Questions
    Last Post: 20 Feb 2010, 05:28 PM
