Well I was hoping that with the entirely new store files that this would have been fixed but sadly it is not.
http://pfddelights.com
is still having trouble with the manufactures side box. we set it to have the drop down menu and all the manfacturers show up but when you click on the ones that have more than 1 product it just takes you back to the main page
if the manufacturer has only 1 product then it goes to that manufacturers page.
it is almost like the database is missing something. When I upgraded her store to 1.3.9b and replaced all the files with the ones from the zip I hopes that would fix it.
any ideas, I will activate the sidebox again for if you want to take a look.
