    Jan 2010
    Default Zen Cart does not recognize my custom page.
    So I've set up a new page in includes/modules/my_template_name/pages/specials/main_template_vars.php, and I've updated the file to make some changes in the layout. But my shopping cart seem to not be reading the template I set up.
    I know the changes I set up are working because I've tried them on the main includes/modules/main_template_vars.php and they work perfectly. I'd rather not have that file be the main dependent file for the layout change, does anyone know of why my cart may not be pulling the correct file for layout?
    Jun 2003
    Newcastle UK
    Default Re: Zen Cart does not recognize my custom page.
    Not sure why you are using main_template_vars.php to override a template.
    Normally, if you just want to override a template, then all you need to do is create the template in
    includes/templates/MY_TEMPLATE/templates/
    see
    https://www.zen-cart.com/tutorials/index.php?article=36
    for more details
    Jan 2010
    Thanks for helping out, the reason I was modifying the file in that location was because I got the home "features" box area to work properly by adding a folder inside the main modules folder, after the name of my template.
    Then I duplicated the "featured_products.php" into my new folder made the modifications I needed and zen cart read it properly. So I assumed the specials page would work the same way. But when i duplicated the specials page and moved it into that folder it did not recognize the changes.
    I knew it was the correct file because if I modified the live one, it worked perfectly.
    should i not be using a templated file in the modules folder at all?
    Aug 2004
    New York City
    Anywhere you see a /classic/ folder, you can create a folder for your custom template.
    Mary Ellen
    I came; I saw; I Zenned
    Taking over the world... one website at a time
    Make sure brain is engaged before putting mouth in gear... or fingers to keyboard.
    Holzheimer
    Fan Odyssey
  1. zen cart does not see my logo image
    By jgroleau in forum General Questions
    Last Post: 20 Jul 2009, 11:28 PM
  2. How does Zen-Cart "know" what your "custom" directory is?
    By alicia1234 in forum Templates, Stylesheets, Page Layout
    Last Post: 4 Dec 2008, 01:46 AM
  3. My Zen Cart does not work after server crash
    By idtags in forum General Questions
    Last Post: 21 Oct 2007, 04:30 PM
