I would like to move my "reviews" sidebox to the center of the homepage. When I turn on the center column display nothing shows up.
It displays fine when set to left side but not center.
Any ideas?
Any ideas?
sideboxes are just that -- sideboxes. They can be either left or right in the "standard" Zen Cart layout. The only way to get a sidebox in the "middle" is to swap the main column with either the left or right column.
Perhaps you meant centering the review button on a products page?
A little help with colors.
No I meant the review box.
I want it in the middle just like the "new products" box.
http://www.avenuebeads.com/
You will need to code it in as the review is only offered as a sidebox or button on the product page.
Well drats. They probably shouldn't give you the option to turn on "center" then.![]()
And where do you find that option?
In the layout boxes controller.
Posted via Mobile Device
There is no center option there. You might be confusing it with single column status which is used if someone were to turn off either the left or right column.
One can use different stylesheets to have different columns turned off for different pages. Thus I could set reviews to only be available when the left column is visible and then only turn the left column on for one category.
So much Zen, so many options
But no centering for a sidebox. The new products and featured products in the main column are not sideboxes but there are sideboxes for them which, again, are limited to showing only in the left or right column.
You would need to clone either the new or featured page(s) and include the code to present the reviews in it.
If you do such a thing, you might consider adding it to the Add Ons area as it looks like no one has done a mod for this.
