Using ZenCart 1.3.9b. CherryZen Template. The Configuration > EZ Pages Settings exists but the Tools > EZ pages is not to be found in the menu.
Can anyone help?
Can anyone help?
You're missing one or more files under the /admin/includes/boxes/ folders, or you've edited the tools file under there such that it's broken, or you've added an addon incorrectly, or you've added the Admin Profiles addon and haven't granted yourself permission to access that feature.
Thanks for the assistance.
I have replaced the files in admin/includes/boxes (including tools file) with clean copies. I have not added the Admin profiles addon. Still do not show the Tools>EZ pages.
I did try to install order manager and was unable to complete the install. I have removed all the identifiable files from order manager and replaced orders.php with a clean file copy. Would this have anything to do with the problem and if so is there another file somewhere that should be replaced with a clean copy?
Ignore that last post. The upload had put the clean files one directory too high. Moved them and EZ pages is BACK!!!!
Thank you!! Thank you!!
