Results 1 to 9 of 9
    Jul 2010
    Default Problem with radio button alignment
    Hi all,
    I'm opening my webstore with ZenCart, everything is fine except this problem :
    I would like to place this box close to the words, I checked all the files and the zen_draw_radio_field are always in the good place.
    Thanks per advance,
    Nicolas.
    Feb 2008
    Default Re: Problem with radio button alignment
    There is no link to site so we can't try to fix the problem when we can't see the live site. I would be shocked if someone knows the solution on top of their hand as this isn't the normal way Zen Cart display these buttons.
    Jul 2010
    Can you post a direct link to your css or the page its on. I would just play with the form css alighment in IE and Firefox to get the alignment correct. Its obviously an issue with that.
    Jul 2010
    Jul 2010
    Anyone can help me please ?
    Feb 2005
    Lansing, Michigan USA
    That doesn't look like something that's fixable using the stylesheet. It looks like a coding blunder by Template Monster, so you might ask them.
    If TM provided a tpl_modules_create_account.php file in your includes/templates/theme224/templates folder, you might try removing that file temporarily to let the default take over and see if it's fixed.
    It can be covered up using the stylesheet, but it would be better to find out why the radiobuttons are skipping past the labels.
    #gender-male+label {position: relative; left: -1.3em; bottom: 0.3em;}
    #gender-female {position: relative; left: 3.5em;}
    #gender-female+label {position: relative; bottom: 0.3em;}
    #newsletter-checkbox+label {position: relative; bottom: 0.3em;}
    #email-format-html+label {position: relative; left: -1.3em; bottom: 0.3em;}
    #email-format-text {position: relative; left: 4.5em;}
    #email-format-text+label {position: relative; bottom: 0.3em;}
    This also fixes a standard-issue misalignment between checkboxes/radiobuttons and their labels (moving the labels up 0.3em).
    Jul 2010
    There is no tpl_module_create_account.php in this file.
    I will try with this code, but where do I put it ?
    Thanks guys,
    Nicolas.
    Jul 2010
    Finaly I found the problem :
    L 17 stylesheet.css :
    I delete the float:left;
  1. v151 Vertical alignment of attribute name to middle of radio button options
    By Dave224 in forum Templates, Stylesheets, Page Layout
    Last Post: 18 Jul 2013, 05:33 PM
  2. How to add radio button attributes with picture?
    By jcrewe in forum Setting Up Categories, Products, Attributes
    Last Post: 23 Aug 2011, 11:25 AM
  3. Radio Button with Open Price
    By valvoj in forum General Questions
    Last Post: 2 Oct 2009, 03:01 AM
  4. Radio button overlaps with attribute image
    By dazed88 in forum Setting Up Categories, Products, Attributes
    Last Post: 15 Oct 2008, 10:53 AM
  5. Replacing option radio button with "Buy Now" button
    By GavCaz in forum Setting Up Categories, Products, Attributes
    Last Post: 31 Aug 2007, 10:17 PM
