I am having the same problem with godaddy hosting. the paypal payflowpro module says
"CURL is used for bidirectional communication with the gateway, so must be active on your hosting server (if you need to use a CURL proxy, set the CURL proxy settings under Admin->Configuration->My Store.)"
i have called godaddy a couple of times and the tech acts like he doesnt know what i am talking about. if i turn off the Curl then i get an error of invalid account info and with the Curl on i get a "Received HTTP code 403 from proxy after CONNECT" error.
any suggestions?
Kyle
