Hi to all,
I just had a programmer install the zencart for my site. But I am having a problem and he doesnt have a clue what the problem or solution is.
The issue is that at the products webpage
(please remove spaces in 2nd and 3rd word of url as I could not post without spaces)
vidanfashio n j e w elry.com/index.php?main_page=product_info&cPath=4&products_id=1
the first add to cart button for main product of page does not work!!
at the home page with no quantity option field it does work add to cart button.
now I have been stuck for a few days with this and no solution I would be very grateful for a solution. please help.
the programmer now claims the problem is because of this setup of appache server with the following
mod_fcgid/2.3.5 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635
and the host says they cant change that unless I take a private server.
do you think this is the problem and if yes is there a way around it? or is this not the problem than what is?
as well can you please tell me if overall the code is proper and clean or not?
thank you for any help...![]()
