Results 1 to 7 of 7
    Aug 2010
    Default Problem after moving main zen cart directory
    Hi, I just installed zen cart today, and I tried to move the main directory from domain.com/shop to domain.com, following a tutorial, but now the home page is just plain html. Here is the URL:
    http://raptorsa.nexcess.net/
    Also, now when I try to log into my admin I get a message saying I need to install magento.
    Default Re: Problem after moving main zen cart directory
    Paste the top half of your /includes/configure.php file here
    Aug 2010
     * @package Configuration Settings circa 1.3.9
     * @copyright Copyright 2003-2010 Zen Cart Development Team
     * File Built by zc_install on 2010-08-22 07:49:24
    /***************       The 2 files should be kept separate and not used to overwrite each other.      ***********/
      define('HTTP_SERVER', 'http://raptorsa.nexcess.net');
      define('HTTPS_SERVER', 'https://raptorsa.nexcess.net');
      define('DIR_WS_CATALOG');
      define('DIR_WS_HTTPS_CATALOG');
      define('DIR_WS_PHPBB', '/');
      define('DIR_FS_CATALOG', '/chroot/home/raptorsa/raptorsairsoft.com/html/');
    Aug 2010
    I fixed it. Thanks
    Aug 2010
    Wait!!! I still can't login to my admin.
    Check the highlighted entries and probably incorrect in your admin file also
    Should be:
    Quote Originally Posted by Raptors View Post
    Um, the Zen Cart admin will never tell you that, unless you've had someone alter the code to do so.
  1. What do I do with old zen cart directory after upgrade?
    By BlackOrchidCouture in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 6 Jun 2011, 07:28 PM
  2. Moving Zen Cart to root directory query
    By KiwiBrian in forum Templates, Stylesheets, Page Layout
    Last Post: 29 Oct 2008, 04:12 AM
  3. Moving zen cart problem
    By tallalex85 in forum Installing on a Linux/Unix Server
    Last Post: 17 Jul 2008, 08:12 AM
  4. Problems after moving my zen cart store
    By Rookie gone MAD! in forum General Questions
    Last Post: 12 Dec 2007, 05:45 PM
