* @package shippingMethod
* @copyright Copyright 2003-2009 Zen Cart Development Team
* @version $Id: ddc.php
* DDC Shipping Module class
class ddc extends base {
* Declare shipping module alias code
* @var string
var $code;
* Shipping module display name
* @var string
var $title;
* Shipping module display description
* @var string
var $description;
* Shipping module icon filename/path
* @var string
var $icon;
* Shipping module status
* @var boolean
var $enabled;
* Shipping module list of supported countries (unique to USPS/UPS)
* @var array
var $types;
* Constructor
* @return ddc
function ddc() {
global $order, $db, $template, $current_page_base;
$this->code = 'ddc';
$this->title = MODULE_SHIPPING_DDC_TEXT_TITLE;
$this->description = MODULE_SHIPPING_DDC_TEXT_DESCRIPTION;
$this->sort_order = MODULE_SHIPPING_DDC_SORT_ORDER;
$this->icon = '';
$this->tax_class = MODULE_SHIPPING_DDC_TAX_CLASS;
$this->tax_basis = MODULE_SHIPPING_DDC_TAX_BASIS;
$this->_allowedMethods = explode(", ", MODULE_SHIPPING_DDC_TYPES);
// disable only when entire cart is free shipping
if (zen_get_shipping_enabled($this->code)) {
$this->enabled = ((MODULE_SHIPPING_DDC_STATUS == 'True') ? true : false);
if ($this->enabled) {
// check MODULE_SHIPPING_DDC_HANDLING_METHOD is in
$check_query = $db->Execute("select configuration_value from " . TABLE_CONFIGURATION . " where configuration_key = 'MODULE_SHIPPING_DDC_HANDLING_METHOD'");
if ($check_query->EOF) {
$db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, set_function, date_added) values ('Handling Per Order or Per Box', 'MODULE_SHIPPING_DDC_HANDLING_METHOD', 'Box', 'Do you want to charge Handling Fee Per Order or Per Box?', '6', '0', 'zen_cfg_select_option(array(\'Order\', \'Box\'), ', now())");
if ( ($this->enabled == true) && ((int)MODULE_SHIPPING_DDC_ZONE > 0) ) {
$check_flag = false;
$check = $db->Execute("select zone_id from " . TABLE_ZONES_TO_GEO_ZONES . " where geo_zone_id = '" . MODULE_SHIPPING_DDC_ZONE . "' and zone_country_id = '" . $order->delivery['country']['id'] . "' order by zone_id");
while (!$check->EOF) {
if ($check->fields['zone_id'] < 1) {
$check_flag = true;
} elseif ($check->fields['zone_id'] == $order->delivery['zone_id']) {
$check_flag = true;
$check->MoveNext();
if ($check_flag == false) {
$this->enabled = false;
$this->types = array('QGND' => 'Ground',
'Q2DA' => '2 Day',
'Q1DA' => 'Next Day');
* Get quote according to the pricing table
* @param string $method
* @return array of quotation results
function quote($method = '') {
global $_POST, $order, $total_count, $shipping_num_boxes;
// adjusted count for free shipping
$this->_itemTotalCount = $total_count - $_SESSION['cart']->free_shipping_items();
if ( (zen_not_null($method)) && (isset($this->types[$method])) ) {
//$prod = $method;
// BOF: UPS USPS
} else if ($order->delivery['country']['iso_code_2'] == 'CA') {
//$prod = 'STD';
// EOF: UPS USPS
//$prod = 'GNDRES';
// Find out what zone the shipping address belongs to
$this->_ddcGetZone($order->delivery['postcode']);
$ddcQuote = $this->_ddcGetQuote();
if ( $this->_ddcShippingZone ) {
switch (SHIPPING_BOX_WEIGHT_DISPLAY) {
case (0):
$show_box_weight = '';
case (1):
$show_box_weight = ' (' . $shipping_num_boxes . ' ' . TEXT_SHIPPING_BOXES . ')';
case (2):
$show_box_weight = ' (' . number_format($ups_shipping_weight * $shipping_num_boxes,2) . TEXT_SHIPPING_WEIGHT . ')';
default:
$show_box_weight = ' (' . $shipping_num_boxes . ' x ' . number_format($ups_shipping_weight,2) . TEXT_SHIPPING_WEIGHT . ')';
$this->quotes = array('id' => $this->code,
'module' => $this->title);
$methods = array();
$qsize = sizeof($ddcQuote);
$std_rcd = false;
for ($i=0; $i<$qsize; $i++) {
list($type, $cost) = $ddcQuote[$i];
if ($type=='STD') {
if ($std_rcd) continue;
else $std_rcd = true;
if (!in_array($type, $this->_allowedMethods)) continue;
$cost = preg_replace('/[^0-9.]/', '', $cost);
$methods[] = array('id' => $type,
'title' => $this->types[$type],//$this->types[$type],
'cost' => $cost + (MODULE_SHIPPING_DDC_HANDLING_METHOD == 'Box' ? MODULE_SHIPPING_DDC_HANDLING * $shipping_num_boxes : MODULE_SHIPPING_DDC_HANDLING) );
$this->quotes['methods'] = $methods;
if ($this->tax_class > 0) {
$this->quotes['tax'] = zen_get_tax_rate($this->tax_class, $order->delivery['country']['id'], $order->delivery['zone_id']);
} else { // If the zip code doesn't belong to any zone
$this->quotes = array('module' => $this->title,
'error' => 'We are unable to obtain a rate quote for Qualia shipping.<br />Please contact the store if no other alternative is shown.');
return $this->quotes;
* check status of module
* @return boolean
function check() {
global $db;
if (!isset($this->_check)) {
$check_query = $db->Execute("select configuration_value from " . TABLE_CONFIGURATION . " where configuration_key = 'MODULE_SHIPPING_DDC_STATUS'");
$this->_check = $check_query->RecordCount();
return $this->_check;
* Install this module
function install() {
global $db;
$db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, set_function, date_added) values ('Enable DDC Shipping', 'MODULE_SHIPPING_DDC_STATUS', 'True', 'Do you want to offer DDC shipping?', '6', '0', 'zen_cfg_select_option(array(\'True\', \'False\'), ', now())");
$db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Handling Fee', 'MODULE_SHIPPING_DDC_HANDLING', '0', 'Handling fee for this shipping method.', '6', '0', now())");
$db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, use_function, set_function, date_added) values ('Tax Class', 'MODULE_SHIPPING_DDC_TAX_CLASS', '0', 'Use the following tax class on the shipping fee.', '6', '0', 'zen_get_tax_class_title', 'zen_cfg_pull_down_tax_classes(', now())");
$db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, set_function, date_added) values ('Tax Basis', 'MODULE_SHIPPING_DDC_TAX_BASIS', 'Shipping', 'On what basis is Shipping Tax calculated. Options are<br />Shipping - Based on customers Shipping Address<br />Billing Based on customers Billing address<br />Store - Based on Store address if Billing/Shipping Zone equals Store zone', '6', '0', 'zen_cfg_select_option(array(\'Shipping\', \'Billing\', \'Store\'), ', now())");
$db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, use_function, set_function, date_added) values ('Shipping Zone', 'MODULE_SHIPPING_DDC_ZONE', '0', 'If a zone is selected, only enable this shipping method for that zone.', '6', '0', 'zen_get_zone_class_title', 'zen_cfg_pull_down_zone_classes(', now())");
$db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Sort order of display.', 'MODULE_SHIPPING_DDC_SORT_ORDER', '0', 'Sort order of display. Lowest is displayed first.', '6', '0', now())");
// BOF: UPS USPS
$db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, set_function, date_added) values ( 'Shipping Methods: Ground, 2 Day, Next Day', 'MODULE_SHIPPING_DDC_TYPES', 'QGND, Q2DA, Q1DA', 'Select the DDC services to be offered.', '6', '13', 'zen_cfg_select_multioption(array(\'QGND\', \'Q2DA\', \'Q1DA\'), ', now() )");
// EOF: UPS USPS
* Remove this module
function remove() {
global $db;
$db->Execute("delete from " . TABLE_CONFIGURATION . " where configuration_key like 'MODULE\_SHIPPING\_DDC\_%' ");
* Build array of keys used for installing/managing this module
* @return array
function keys() {
return array('MODULE_SHIPPING_DDC_STATUS', 'MODULE_SHIPPING_DDC_HANDLING', 'MODULE_SHIPPING_DDC_HANDLING_METHOD', 'MODULE_SHIPPING_DDC_TAX_CLASS', 'MODULE_SHIPPING_DDC_TAX_BASIS', 'MODULE_SHIPPING_DDC_ZONE', 'MODULE_SHIPPING_DDC_SORT_ORDER', 'MODULE_SHIPPING_DDC_TYPES');
* DDC SHIPPING CALCULATOR
function _ddcGetZone($zip) {
global $db, $order;
$zone = '';
// strip the first 3 digits
$zip = substr($zip, 0, 3);
if ($order->delivery['state']=='New Jersey') {
$zone = 40;
else if ($order->delivery['state']=='Hawaii') {
$zone = 20;
else if ($order->delivery['state']=='Alaska') {
$zone = 30;
// If not any of the above states, query the database
else {
$check_query = $db->Execute("select zone from qualia_ddc_zones where start_zip<=" . $zip . " AND end_zip>=" . $zip);
$check_query->fields['zone'];
$zone = $check_query->fields['zone'];
$this->_ddcShippingZone = $zone;
function _ddcGetQuote() {
global $db;
$returnval = array();
$totalBottles = $this->_itemTotalCount;
$shippingMethods = $this->_allowedMethods;
// print_r( $_SESSION['shipping']);
// popuplate the quote array
for ($i=0; $i<sizeof($this->_allowedMethods); $i++) {
if ($totalBottles > 12) {
$num_cases = floor($totalBottles/12);
$remaining_bottles = $totalBottles%12;
$check_query = $db->Execute("select zone" . $this->_ddcShippingZone . " from qualia_ddc_shipping_" . strtolower($shippingMethods[$i]) . " where bottles=12");
$case_shipping = $check_query->fields['zone'.$this->_ddcShippingZone] * $num_cases;
$check_query = $db->Execute("select zone" . $this->_ddcShippingZone . " from qualia_ddc_shipping_" . strtolower($shippingMethods[$i]) . " where bottles=" . $remaining_bottles);
$remaining_shipping = $check_query->fields['zone'.$this->_ddcShippingZone];
$total_shipping = $case_shipping + $remaining_shipping;
$returnval[$i][0] = $this->_allowedMethods[$i];
$returnval[$i][1] = $total_shipping;
else if ($totalBottles <= 12) {
$check_query = $db->Execute("select zone" . $this->_ddcShippingZone . " from qualia_ddc_shipping_" . strtolower($shippingMethods[$i]) . " where bottles=" . $totalBottles);
$returnval[$i][0] = $shippingMethods[$i];
$returnval[$i][1] = $check_query->fields['zone'.$this->_ddcShippingZone];
return $returnval;
