    Sep 2010
    Default Help Setting up Cart
    Hi - I recently installed Zen Cart using Fantastico on my hosts CPanel. All went well and I successfully linked it to my website.
    Her is what I see now: http://www.oakhillperennials.com/shop/
    From what I read so far about installation I now have to edit the many .php files using notepad or a similar editor. I have NotePad to use to do this.
    Can anyone point me to a document, tutorial, etc. that will take me step-by-step through the editing process?
    Thanks in advance,
    Pete
    Aug 2004
    New York City
    Default Re: Help Setting up Cart
    There's lots of information in the Tutorials/FAQ and the Wiki.
    Mary Ellen
    I came; I saw; I Zenned
    Taking over the world... one website at a time
    Make sure brain is engaged before putting mouth in gear... or fingers to keyboard.
    Holzheimer
    Fan Odyssey
    Sep 2010
    Thanks Mary Ellen.
    Can anyone else suggest a starting point ?
    Pete
    Sep 2010
    OK, for all the other Newbies out there, here is the first step in editing your Zen Cart:
    Access your Zen cart admin area via your BROWSER by pointing to either:
    - http://www.YOUR_SITE.COM/admin/index.php OR
    - http://www.YOUR_SITE.COM/foldername/admin/index.php
    Easy huh?
    Pete
    A dedicated file editor like Notepad++ (free from Sourceforge) is better than Notepad for editing, as it will highlight syntax and often show you when you have made a simple mistake in editing, like a missed ' or ; that can cause a fatal error.
    Aug 2004
    New York City
    Quote Originally Posted by pcs2010 View Post
    Easy huh?
    Pete
    Yes, that will get you into your admin. Won't necessarily help with editing files.
    For security purposes, you should rename your admin.
    Mary Ellen
    Holzheimer
    Fan Odyssey
  1. help setting up my cart
    By indyshop2468 in forum Basic Configuration
    Last Post: 2 Jul 2010, 03:39 PM
  2. New to Zen cart. Need help setting up my pages.
    By Yukmouth in forum Templates, Stylesheets, Page Layout
    Last Post: 17 Mar 2010, 06:15 PM
  3. Help with SSL and setting up the Shopping cart to run it.
    By cushietushies in forum General Questions
    Last Post: 22 Sep 2008, 01:27 AM
  4. zen cart newbie,plz help with 2 layout setting questions
    By harz in forum Templates, Stylesheets, Page Layout
    Last Post: 19 Sep 2008, 05:27 PM
