Results 1 to 5 of 5
    Default Using Linkpoint/YourPay API module with Zen Cart Zen Cart 1.3.0.1
    I am using the Paypal API module with the following Zen Cart version:
    Zen Cart 1.3.0.1
    Database Patch Level: 1.3.0.2
    I have been asked to make the Zen Cart shopping cart also work with the Link Data system (Linkpoint/YourPay API module). I see that the Linkpoint/YourPay API module is available in version 1.3.8a.
    Is there any way at all to use the Linkpoint/YourPay API module in the 1.3.0.1 version I am using?
    Many thanks as always.
    Default Re: Using Linkpoint/YourPay API module with Zen Cart Zen Cart 1.3.0.1
    Your v1.3.0.1 site is VERY old, and has known serious security problems, discovered and reported and fixed in June 2009. All forum members were notified by email of the urgent need to upgrade to protect your site from those problems.
    Plus, versions older than v1.3.7 are officially no longer supported. And, naturally just because of age, it's harder to find compatible versions since all addons are generally designed for the newer versions, not the very old one you're using.
    Whoever is asking you to update the site should be informed of the urgent need to upgrade, with the natural byproduct of that being that the desired support for Linkpoint will be built-in already.
    Thanks for the feedback and advice Dr.
    The version is running all of the security updates and to date has not had any incident, but I an aware that it is nearly obsolete. The hold-back is caused by all of the modifications I have put into it, but in order to use the First Data gateway there is no longer any decision but to make the change.
    Once again thanks for taking the time to give me a helpful and knowledgeable reply.
    Here's a hidden link to an old linkpoint addon that was originally designed to work on 1.3.0.
    I recommend only using it as a bridge until you complete your upgrade, because it likely contains bugs.
    Dr.
    Thank you very much for providing me that link. I will move forward in the upgrade process and take your advice about using the add on module only as a bridge until I have completed the upgrade.
  1. Voiding an Order using LinkPoint & Zen Cart
    By Griff1324 in forum General Questions
    Last Post: 7 Jul 2008, 03:01 AM
  2. mySQL error with YourPay gateway using old version of Zen Cart
    By apathy in forum Built-in Shipping and Payment Modules
    Last Post: 10 May 2008, 04:30 AM
  3. Linkpoint payment module to zen cart 1.38
    By andy106 in forum Addon Payment Modules
    Last Post: 31 Dec 2007, 02:02 AM
  4. using non-zen cart templates with zen cart
    By ssbeats in forum General Questions
    Last Post: 26 Jun 2007, 09:16 PM
