    Sep 2010
    help question Problem with new shipping module ported from osc
    I have a problem with new shipping module which initially was written for oscommece but I modified it for zencart in accordance with this article: http://www.zen-cart.com/wiki/index.p...dules_from_osC
    Module was properly installed and properly works in admin panel but when I add any product to the cart from client side and I try to cross to the "checkout shipping" stage I see a blank page.
    I checked logs and there are following errors:
    Call to undefined function zen_db_fetch_array()   on line 35
    and
    Cannot use object of type queryFactoryResult  on line 39
    I tried various solutions but I still receive a blank page and errors in logs. Could you help me in find proper solution for this problem, please?
    Piece of module which generates errors:
      function pobierz_klienta() {
        global $customer_id, $sendto, $db;
        $account_query = $db->Execute("select
        customers_email_address from
        " . TABLE_CUSTOMERS . " where customers_id = '" . (int)$customer_id . "'");
        $account = zen_db_fetch_array($account_query);
    	  $klient['email']=$account['customers_email_address'];
        entry_postcode from
        " . TABLE_ADDRESS_BOOK . " where address_book_id = '" . (int)$sendto . "'");
        $klient['kod']=$account['entry_postcode'];
        return $klient;
    Default Re: Problem with new shipping module ported from osc
    There's no such thing as "zen_db_fetch_array" function. There are several examples, in the link you mentioned, of the correct approach for porting those lines over.
    Sep 2010
    I think that I modified this script accordingly with the solution but unfortunately it still doesn't work in 100% properly (script doesn't send postcode to the external server etc.). Could someone tell me what I done wrong?
    class paczkomaty {
      var $code, $title, $description, $enabled, $num_zones;
      function paczkomaty() {
      	global $order, $total_weight;
        $this->code = 'paczkomaty';
        $this->title = MODULE_SHIPPING_PACZKOMATY_TEXT_TITLE;
        $this->description = MODULE_SHIPPING_PACZKOMATY_TEXT_DESCRIPTION;
        $this->sort_order = MODULE_SHIPPING_PACZKOMATY_SORT_ORDER;
        $this->icon = 'http://media.paczkomaty.pl/pieczatka.gif';
        $this->tax_class = MODULE_SHIPPING_PACZKOMATY_TAX_CLASS;
        $this->enabled = ((MODULE_SHIPPING_PACZKOMATY_STATUS == 'True') ? true : false);
        $this->num_zones = 1;
        $klient['email']=$account_query->fields['customers_email_address'];
        entry_postcode from
        $klient['kod']=$account_query->fields['entry_postcode'];
        return $klient;
      function pobierz_paczkomaty($postcode) {
        $inpost_api_url = constant('MODULE_SHIPPING_PACZKOMATY_API_URL');
        if ($machinesContents = @file_get_contents("$inpost_api_url/?do=findnearestmachines_csv&postcode=$postcode")) {
          if ($machinesContents=='Error') return 0;
          $machinesArray = split("\n",$machinesContents);
          if (count($machinesArray)) {
            foreach ($machinesArray as $machine) {
              $machine = split(";",$machine);
              $data[] = $machine;
            return $data;
        return 0;
      function znajdz_klienta($email) {
        if ($machinesContents = @file_get_contents("$inpost_api_url/?do=findcustomer_csv&email=$email")) {
          $machine = split(";", $machinesContents);
          return $machine;
        return 0;
      function quote($method = '') {
    	  global $order, $total_weight, $shipping_weight, $shipping_num_boxes, $customer_id, $sendto;
        $klient =$this->pobierz_klienta();
        $dest_country = $order->delivery['country']['iso_code_2'];
        $dest_zone = 0;
        $error = false;
        if ($order->delivery['country']['iso_code_2'] == 'PL')  {  // tylko na terenie Polski
          for ($i=1; $i<=$this->num_zones; $i++) {
            $countries_table = constant('MODULE_SHIPPING_PACZKOMATY_COUNTRIES_' . $i);
            $country_zones = split("[,]", $countries_table);
            if (in_array($dest_country, $country_zones)) {
              $dest_zone = $i;
          if ($dest_zone == 0) {
            $this->quotes['error'] = MODULE_SHIPPING_ZONES_INVALID_ZONE;
            return $this->quotes;
          $shipping_method = MODULE_SHIPPING_PACZKOMATY_TEXT_WAY . ' : ' . $shipping_weight . ' ' . MODULE_SHIPPING_PACZKOMATY_TEXT_UNITS . ' ' . MODULE_SHIPPING_PACZKOMATY_DELIVERY_TIMES;
          $shipping_cost = constant('MODULE_SHIPPING_PACZKOMATY_COST_' . $dest_zone)* $shipping_num_boxes;
        if (zen_not_null($this->icon)) $this->quotes['icon'] = zen_image($this->icon, $this->title);
        if ($dest_zone == 0) {   // poza rejonem
       	if ($total_weight >12) { // nie pokazuj dla przesylek > 12kg
          $this->quotes['error'] = MODULE_SHIPPING_PACZKOMATY_UNDEFINED_RATE;
        $this->quotes = array('id' => $this->code,
                              'module' => MODULE_SHIPPING_PACZKOMATY_TEXT_TITLE);
        $paczkomaty=$this->pobierz_paczkomaty($klient['kod']);
        if (!$paczkomaty) {
    			$this->quotes['error'] = MODULE_SHIPPING_PACZKOMATY_TEXT_MACHINES_NOT_FOUND;
        $paczkomat_domyslny=$this->znajdz_klienta($klient['email']);
        if (!$paczkomat_domyslny) {
    			$this->quotes['error'] = MODULE_SHIPPING_PACZKOMATY_TEXT_USER_NOT_FOUND;
        $this->quotes['methods'][]=array('id' => $this->code,
                                         'title' => 'Paczkomat domyślny '.$paczkomat_domyslny[0].', '.$paczkomat_domyslny[1],
                                         'cost' => $shipping_cost);
        if (count($paczkomaty)) {
          foreach ($paczkomaty as $paczkomat) {
                                              'title' => 'Paczkomat '.$paczkomat[0].', '.$paczkomat[1].', ('.$paczkomat[3].'km od '.$klient['kod'].")",
      function check() {
        global $db;
        if (!isset($this->_check)) {
          $check_query = $db->Execute("select configuration_value from " . TABLE_CONFIGURATION . " where configuration_key = 'MODULE_SHIPPING_PACZKOMATY_STATUS'");
          $this->_check = $check_query->RecordCount();
        return $this->_check;
      function install() {
        global $db;
        $db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, set_function, date_added) VALUES ('Włącz wysyłkę do paczkomatów', 'MODULE_SHIPPING_PACZKOMATY_STATUS', 'True', 'Czy chcesz dodać opcję wysyłki do paczkomatów?', '6', '0', 'zen_cfg_select_option(array(\'True\', \'False\'), ', now())");
        $db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Ściezka do api', 'MODULE_SHIPPING_PACZKOMATY_API_URL', 'https://api.paczkomaty.pl', 'Ścieżka do api paczkomaty', '6', '0', now())");
        $db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Sortowanie', 'MODULE_SHIPPING_PACZKOMATY_SORT_ORDER', '1', 'Sortowanie', '6', '0', now())");
        for ($i = 1; $i <= $this->num_zones; $i++) {
          $default_countries = '';
          if ($i == 1) {
            $default_countries = 'PL';
          $db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Dostępne kraje', 'MODULE_SHIPPING_PACZKOMATY_COUNTRIES_" . $i ."', '" . $default_countries . "', 'WprowadĽ oznaczenie kraju dla którego usługa jest dostępna (Default: PL)', '6', '0', now())");
          $db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Cena przesyłki', 'MODULE_SHIPPING_PACZKOMATY_COST_" . $i ."', '6.99', 'Domyślny koszt wysyłki', '6', '0', now())");
      function remove() {
        global $db;
        $db->Execute("delete from " . TABLE_CONFIGURATION . " where configuration_key in ('" . implode("', '", $this->keys()) . "')");
      function keys() {
        $keys = array('MODULE_SHIPPING_PACZKOMATY_STATUS', 'MODULE_SHIPPING_PACZKOMATY_API_URL', 'MODULE_SHIPPING_PACZKOMATY_SORT_ORDER');
          $keys[] = 'MODULE_SHIPPING_PACZKOMATY_COUNTRIES_' . $i;
          $keys[] = 'MODULE_SHIPPING_PACZKOMATY_COST_' . $i;
        return $keys;
    I believe the problem is in the $sendto variable ...
    As an Example, you have:
        entry_postcode from
    From what I can see, that variable doesn't equal anything, unless you happen to go to the Shipping Estimator and then it will be set to what the customer is looking at on the shipping estimator but not necessarily what they select on checkout ...
    What if instead you use for $sendto:
    $_SESSION['sendto']
    Sep 2010
    I modified to
        global $db;
        " . TABLE_CUSTOMERS . " where customers_id = '" . $_SESSION['customer_id'] . "'");
        entry_postcode from
        " . TABLE_ADDRESS_BOOK . " where address_book_id = '" . $_SESSION['sendto'] . "'");
        return $klient;
    and it works perfectly. Thank you very much and have a nice day :)
    You are most welcome ... thanks for the update that you were just using the wrong variable and now things are working ...
  1. array_merge error on ported OSC database
    By edadk in forum General Questions
    Last Post: 14 Nov 2008, 01:18 AM
  2. shipping module convert from osc help
    By FrilansReklam in forum Addon Shipping Modules
    Last Post: 8 Oct 2008, 06:38 PM
  3. Fedex Freight Module ported from OsCommerce
    By chadderuski in forum Addon Shipping Modules
    Last Post: 16 May 2008, 04:50 PM
  4. PriceTag Payment Module Ported From OsCommerce
    By psychox in forum Addon Payment Modules
    Last Post: 3 Jan 2007, 05:44 PM
