Hi all,
Does anyone know if it's possible to stop spiders from incrementing the products viewed entries?
I would really like to know what my customers are looking at not the spiders..
Cheers,
Phil
Hi all,
Cheers,
Phil
The counter is in the:
/includes/modules/pages/product_info/main_template_vars.php
You should be able to surround that with an IF so that spiders are not counted:
Code:if ($spider_flag == false) { // products_viewed code }
If you have that on the one under the select for:
Then it should work ...Code:$sql = "update " . TABLE_PRODUCTS_DESCRIPTION . " set products_viewed = products_viewed+1 where products_id = '" . (int)$_GET['products_id'] . "' and language_id = '" . (int)$_SESSION['languages_id'] . "'"; if ($spider_flag == false) { $res = $db->Execute($sql); }
Be sure to test this and see how well the changes work for you and that it still counts guests and customers ...
Yeah I did this:
seems to be working for customers/visitors just watching for spiders now :o)PHP Code://added to stop spiders incrementing
couldn't be bothered to wait, fetched as googlebot from webmaster tools and no increment so seems to work a treat :)
Surprised this isnt already built in!
Phil
Thanks for confirming that this worked for you ...
Some may want to know all counts ...
Personally, I'd like to see a count for spiders separate from the guest/customers ... but that is just me ...![]()
Yeah could add an additional column in the table and have the second query run on the opposite logic to the if statement and then have the report show both.
I agree as it's still important to see that spiders are crawling all products so is an easy reference to check this.
Phil :)
The basic idea is that there is a flag set for:
$spider_flag
so when the Counter tables are updated, you would do one thing for spiders and one thing for none spiders ...
