Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 135
  1. #21
    Default Re: Problem with Paypal connection - Error (28) connect() timed out!
    If you don't add ?paypal=1 to the curltester URL, then it won't test PayPal for you.
    Use: /extras/curltester.php?paypal=1
    Explained here: http://www.zen-cart.com/showthread.p...-Testing-Tools
    A (28) Connect timed out message is ALWAYS a hosting problem, if you've properly got the CURL Proxy disabled. Especially if it "suddenly" breaks. Your hosting company will need to fix it.
  2. #22
    Jan 2009
    I finally ran the proper curltest and this came back:
    28 connect() timed out!
    Array
    [url] => "https://api-3t.paypal.com/nvp"
    [content_type] =>
    [http_code] => 0
    [header_size] => 0
    [request_size] => 0
    [filetime] => -1
    [ssl_verify_result] => 0
    [redirect_count] => 0
    [total_time] => 20.019488
    [namelookup_time] => 0.00557
    [connect_time] => 0
    [pretransfer_time] => 0
    [size_upload] => 0
    [size_download] => 0
    [speed_download] => 0
    [speed_upload] => 0
    [download_content_length] => -1
    [upload_content_length] => -1
    [starttransfer_time] => 0
    [redirect_time] => 0
    EOF
    I am contacting my HOST immediately to get this resolved.
    Thanks DrByte
  3. #23
    Oct 2005
    Chicago, IL USA
    I have a client with the same timing out errors and getting worse. I called PayPal. They tell me they are aware of ATT blocking some of their traffic. They suggested I email [email protected]. My email bounced back ' The recipient's mailbox is full and can't accept messages now. Please try resending this message later, or contact the recipient directly.'
    I did a traceroute to api-3t.paypal.com and did confirm it times out.
    Seems to me, and correct me if I'm wrong, but this is an ATT/PayPal problem and not anything to do with hosting, settings or configurations that we can control.
  4. #24
    And if it is indeed an ATT problem then your hosting company needs to contact ATT, and you need to also report the problem to PayPal so they can also put pressure on ATT to resolve it. That IS something you can do: get the other parties to make the phone calls to fix it.
  5. #25
    Oct 2005
    Chicago, IL USA
    PayPal was the one who told me about the problem and they say it's been going on since last November. Apparently ATT has fairly recently acknowledged the problem, which is a start, but obviously little progress has been made or promised.
  6. #26
    Fair. Still, if nobody keeps reminding them that it's a problem, it won't get solved.
    So ... make sure ATT gets pressure from both ends.
  7. #27
    Mar 2005
    Just an FYI, after having multiple installs of Zencart on the same Ipower host, this exact issue has just crept up started this Sunday March 17, 2013
    Curltester is showing me:
    Array
    [content_type] =>
    [http_code] => 0
    [header_size] => 0
    [request_size] => 0
    [filetime] => -1
    [total_time] => 20.019673
    [namelookup_time] => 0.003141
    [connect_time] => 0
    [size_upload] => 0
    [speed_upload] => 0
    EOF
    Contacted host to see what they changed, has to be them..
    PHPINFO() Shows CURL installed, PHP Install looks like it has not changed in 2 years..
    Will update when resolved just in case it helps others..
  8. #28
    ipower has been reported to have had the same problem numerous times over the last several months.
  9. #29
    Dec 2008
    Iowa
    I'm having the error 28 timeout issue. It started about 48 hours ago and no one can make a payment now. DrByte says it's always a hosting issue, which I agree with, but how do you get them acknowledge that, instead of Register and Paypal pointing at each other?
  10. #30
    Use the curltester tool discussed above, and point them to it.
    If they won't fix it, talk to the top dog at the hosting company and explain to them how unhappy you are with their service, yadda yadda yadda. If they want to keep your business, they'll do something about it.
  1. v153 (7) Failed to connect to api-3t.paypal.com port 443: Connection timed out
    By MCS_Computers in forum PayPal Express Checkout support
    Last Post: 26 Jul 2018, 06:09 AM
  2. v150 PayPal Error (28) - connection timed out - website payments down
    By aiko70 in forum PayPal Express Checkout support
    Last Post: 26 Jul 2013, 05:07 AM
  3. v139d 28 connect timed out error
    By annedig in forum Upgrading to 1.5.x
    Last Post: 10 May 2013, 05:28 PM
  4. v139h PayPal Timeouts (28) Connect timed out!
    By jgold723 in forum PayPal Express Checkout support
    Last Post: 24 Mar 2013, 11:23 PM
  5. paypal express (7) couldn't connect to host & (28) connect() timed out
    By delia in forum PayPal Express Checkout support
    Last Post: 9 Sep 2010, 12:36 PM
