Results 1 to 10 of 15
    Jul 2010
    Default Keep Cart Module - cart won't empty after checkout
    Hello, after install keep cart module everything works well but after order complete the cart does't empty. How can i fix this?
    Apr 2007
    Herts. UK
    Default Re: Keep Cart Module - cart won't empty after checkout
    The cookie that holds the cart contents should be cleared when you reach the checkout confirmation page. Have you made any modifications to your checkout flow? What version of Zen Cart are you using and what add-ons do you have installed?
    Christian.
    Jul 2010
    My version is 1.38a and i have many modules installed. The only one with modded checkout is fast checkout by numinix. I'm searching hours to find a solution. My site is http://www.e-matrix.gr
    Apr 2006
    Texas
    Take time to upgrade to 139h for important security reasons and vicious hacks...
    Take a look at #2 here:
    Apr 2007
    Herts. UK
    Quote Originally Posted by baracudamax View Post
    If the fast checkout mod bypasses the final checkout confirmation screen then Keep Cart won't work with it.
    Regards,
    Christian.
    We are using the Fast & Easy Checkout with Keep Cart without any problems. On both an older site with an older version of FEC and also a new 1.3.9h site with the latest version of FEC. Have you tried it with a different browser to make sure it's not a cache issue?
    Zen Cart and it's community are the best!!
    Jul 2010
    Thank you for your help but I can't find a solution. I've tried other browsers and i have the same problem. I can't upgrade my version because most of my files are custom and i don't have time to merge. Only God can help me....
    Oct 2005
    red flag Re: Keep Cart Module - cart won't empty after checkout
    Once a Visitor logs in shouldn't the cookie get cleared as the cart contents are stored in the database and the purpose is served ??
    There might be a setting that needs to be changed in your admin configuration. What are the settings in admin>configuration>sessions? These are mine:
    Cookie Domain True
    Force Cookie Use False
    Check SSL Session ID False
    Check User Agent False
    Check IP Address False
    Prevent Spider Sessions True
    Recreate Session False
    IP to Host Conversion Status true
    Keep Vistors Cart True
    Days Before Cart Expires 365
    Keep Cart Secret Key xxxxx
    Unrelated to Keep Cart stuff ...
    Quote Originally Posted by lankeeyankee View Post
    That should almost ALWAYS be set to True.
    Leaving it set to false could put you at risk of session hijacking.
    There are RARE server configurations that cause the store to break if it's set to True, and thus the option to set it to False is offered ... but still has the same caveat. MUCH BETTER is to fix the bad server configuration if you care about customer privacy and security.
  1. Shopping cart won't empty after check out
    By spleify in forum General Questions
    Last Post: 13 Oct 2010, 04:59 PM
  2. "Your shopping cart is empty!" error after adding item to cart...
    By pappaj333 in forum Installing on a Linux/Unix Server
    Last Post: 14 Aug 2010, 04:58 PM
  3. security token + empty cart after adding Google Checkout
    By aerosmith in forum Addon Payment Modules
    Last Post: 30 Oct 2008, 10:48 AM
