Results 1 to 9 of 9
    Sep 2006
    North Devon, England, UK
    Default Hide attributes dropdown when using attribute images and Element Below Image and Opt
    latest zen cart
    http://www.jarbon.com/index.php?main...roducts_id=143
    If you scroll down you can see the list of attributes and corresponding swatch image, with options to use checkbox to select atribute.
    i have done this by adding a swatch image to each option and then configuring the attribute name, in this instance 'Knit By Numbers', with these settings: Element Below Image and Option Name (number 4)
    this is all working fine, but i would like to be able to hide the drop down list which remains, but cannot see how to achieve this
    is this possible?
    Feb 2005
    Lansing, Michigan USA
    Default Re: Hide attributes dropdown when using attribute images and Element Below Image and
    Assuming you wanted the dropdown gone on every product info page, you could add something like this to your stylesheet:
    #productAttributes .main {display:none;}
    Sep 2006
    thanks steve
    only want to hide drop down for this page
    css would be a great solution, but can't see how to single this one particular drop down for this page
    would be good if could add css to specific pages, e.g. have unique body id for each page
    not sure if this is possible or if there is a contrib, haven't found one thus far
    Apr 2006
    Texas
    Try this to see if she works then test it out..
    Locate this:
    includes/templates/jarbon/css/stylesheet.css
    Find this:
    #productAttributes select {
    border: 1px solid #CFCFCF;
    padding: 7px;
    1. Add this:
    2. display: none;
    Feb 2005
    Quote Originally Posted by mattys View Post
    You can. There's a file in includes/templates/classic/css that explains the basics.
    Sep 2006
    thanks haredo
    unfortunately this WILL hide selects for all products, which, as stated above, i do not want to happen, only need for this page
    Sep 2006
    steve
    i have looked at this file, doesn't give too much away, in fact, nothing really!
    it says what it can do, but doesn't explain how, i also looked for common folder in classic, but no common folder there, not on my installation anyway, and i wouldn't have deleted it...
    to style individual pages would require some kind of style in the body tag, you could then apply page specific formatting
    do you know of any other sources of info for this?
    Sep 2006
    ah, i see
    just found this:
    http://www.zen-cart.com/forum/showth...dividual+pages
    makes more sense now
    Sep 2006
    bingo
    thanks steve, that was a good nudge in right direction
  1. v151 Hide price in dropdown list when pricing by attribute eg: (+£7.50)
    By mickyholmes in forum Setting Up Categories, Products, Attributes
    Last Post: 14 Oct 2012, 01:48 PM
  2. Dropdown with images and attributes
    By zc_fan in forum Customization from the Admin
    Last Post: 14 Jun 2011, 12:46 PM
  3. Layout change?: Product Image centered and attributes/descriptions/add to cart below
    By worshamdesigns in forum Templates, Stylesheets, Page Layout
    Last Post: 3 Dec 2010, 08:11 AM
  4. Dropdown element below option name
    By ktomas in forum Templates, Stylesheets, Page Layout
    Last Post: 20 Jul 2009, 05:17 AM
  5. Multiple attributes and attribute images...
    By modernm in forum Setting Up Categories, Products, Attributes
    Last Post: 25 Mar 2008, 04:32 AM
