Results 1 to 2 of 2
    Aug 2010
    Washington, DC
    Default Help with EZ Populate
    I am getting the generic error
    SKIPPED! - Product Index: - No existing category provided for this new product
    The problem is that I have been working from a template file, and I have all the fields filled in as I have imported before.
    I checked the debug file and it referenced:
    MySQL error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ' metatags_products_name_status = , metatags_model_status = , metatags_price_stat' at line 1
    When executing:
    UPDATE products SET metatags_title_status = , metatags_products_name_status = , metatags_model_status = , metatags_price_status = , metatags_title_tagline_status =  WHERE products_id = 180918
    I updated the fields= 1, and still no luck.
    Any ideas?
    Jun 2009
    Orange County, California
    Default Re: Help with EZ Populate
    You might try posting this in the EZ Populate support thread.
    http://www.zen-cart.com/forum/showthread.php?t=34970
    That said, You might try re-uploading the Easy Populate files and run Installation SQL again.
    BACKUP everything first!
  1. Easy Populate 1.2.5.5 with Stock With Attributes Help please
    By shahram in forum All Other Contributions/Addons
    Last Post: 4 Oct 2012, 07:56 PM
  2. Help with easy populate V1.2.5.4
    By arogaya in forum All Other Contributions/Addons
    Last Post: 7 Mar 2011, 12:07 AM
  3. Help with Easy Populate
    By danilyn22 in forum All Other Contributions/Addons
    Last Post: 23 Dec 2008, 01:36 AM
  4. help with easy populate
    By atjhza in forum All Other Contributions/Addons
    Last Post: 26 Nov 2008, 12:38 PM
