Results 1 to 2 of 2
    Jan 2009
    Default Tried updating and now need help!
    This is the error on my site.
    Parse error: syntax error, unexpected $end in /hermes/web01/b170/moo.thelivewire/cart/index.php on line 530
    I tried to use a tool called simple scripts on FatCow's control panel to upgrade to the latest version. I was only one version from the latest one and now my site is down and FatCow wont help me without me paying them to fix what their simple scripts broke. Can someone help me with this? I have filezilla started and a backup but dont know how to install it.
    Sep 2005
    Waikato, New Zealand
    Default Re: Tried updating and now need help!
    Quote Originally Posted by LiveWire View Post
    Ok read this
    http://www.zen-cart.com/forum/showthread.php?t=166875
    1) Never ever use an auto upgrade script, and most hosts won't fix it I am afraid
    2) Really you only need to replace a few files to upgrade from 1.3.9g to h, if you download 1.3.9h from here and read the readme it will tell you the files that need to be changed, you just need to check to see wether your add-ons have altered those changed files
    Webzings Design
    Semi retired from Web Design
  1. Replies: 17
    Last Post: 15 Mar 2016, 07:40 PM
  2. tried to install easy populate csv and now i cant login to admin
    By kreynolds in forum All Other Contributions/Addons
    Last Post: 12 May 2010, 06:09 AM
  3. Help please i tried to upgrade and rename didn't work so went back and now its a mess
    By littlemissglamour in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 8 Oct 2009, 01:28 AM
  4. I have done as much as I can and now need help
    By LaineyS in forum Templates, Stylesheets, Page Layout
    Last Post: 6 Feb 2009, 02:21 PM
  5. Tried Installing Grid Layout and Now Page Messed Up. HELP!
    By riotproject in forum All Other Contributions/Addons
    Last Post: 22 Sep 2008, 10:00 AM
