    Oct 2010
    Default Products filtering problems
    I have posted this on the other section, but I believe here is more appropriate.
    I have a website that sells cell phone accessories (www.impspecial.com), as you know there are a lot of manufactures and lots of accessories. For example, I have broke down into cases>mobile>device brand
    Now once you get to the device brand, if they are looking for an otterbox, they are have to go thru all of my hundreds of products. I would like to insert more filters, such as... brand, color, etc.
    Any ideas on how I could do it?
    May 2010
    Default Re: Products filtering problems
    I suggest you to work on "cloning" the existing manufacturer filter. It's quite complicated, but possible. It took to me around 4 days to do it. I've done it some months ago so I don't remember exactly...The only thing I can say, study with much attention on Manufacturer filter. The thing is the same, but obviously you won't filter manufacturers names but other "features" that you'll have to add to your database in a new table.
    Oct 2010
    Thank you for the response
    If you did in 4 days you did great.
    I am trying to do exactly what you said, but it takes time, and I have a lot of products.
    Is there a way to create a product and link it as you are creating it?
    i thought that surely there would be a much easier way to do it.
    Thanks anyway
    Oct 2010
    Is there a easier way to do this besides cloning.
    I have about 3,000 products, and cloning will take a long time.
    How can i create a filter as a side bar?
    Any ideas will be greatly appreciated!
  1. v151 Sorting and filtering products in a category
    By nikerymis in forum Setting Up Categories, Products, Attributes
    Last Post: 21 Oct 2013, 01:50 PM
  2. Filtering Products by Size Attribute
    By largesse1 in forum Setting Up Categories, Products, Attributes
    Last Post: 22 May 2011, 12:04 AM
  3. Filtering Products
    By wdd49 in forum Setting Up Categories, Products, Attributes
    Last Post: 2 Oct 2010, 04:58 PM
  4. Changing Shopping Cart images and filtering products
    By bugstumper in forum Templates, Stylesheets, Page Layout
    Last Post: 4 Aug 2008, 01:54 PM
