I was adding the Fedex shipping module and did everything exactly like it said in the instructions but for some reason now I went go click on check-out, it gives me an error and a blank page.
tpl_footer.php
PHP script text
* Common Template - tpl_footer.php
* this file can be copied to /templates/your_template_dir/pagename<br />
* example: to override the privacy page<br />
* make a directory /templates/my_template/privacy<br />
* copy /templates/templates_defaults/common/tpl_footer.php to /templates/my_template/privacy/tpl_footer.php<br />
* to override the global settings and turn off the footer un-comment the following line:<br />
* <br />
* $flag_disable_footer = true;<br />
* @package templateSystem
* @copyright Copyright 2003-2010 Zen Cart Development Team
* @version $Id: tpl_footer.php 15511 2010-02-18 07:19:44Z drbyte $
require(DIR_WS_MODULES . zen_get_module_directory('footer.php'));
if (!isset($flag_disable_footer) || !$flag_disable_footer) {
<!--bof-navigation display -->
<div id="navSuppWrapper">
<div id="navSupp">
<ul>
<li><?php echo '<a href="' . HTTP_SERVER . DIR_WS_CATALOG . '">'; ?><?php echo HEADER_TITLE_CATALOG; ?></a></li>
<?php if (EZPAGES_STATUS_FOOTER == '1' or (EZPAGES_STATUS_FOOTER == '2' and (strstr(EXCLUDE_ADMIN_IP_FOR_MAINTENANCE, $_SERVER['REMOTE_ADDR'])))) { ?>
<li><?php require($template->get_template_dir('tpl_ezpages_bar_footer.php',DIR_WS_TEMPLATE, $current_page_base,'templates'). '/tpl_ezpages_bar_footer.php'); ?></li>
<?php } ?>
</ul>
<!--eof-navigation display -->
<!--bof-ip address display -->
if (SHOW_FOOTER_IP == '1') {
<div id="siteinfoIP"><?php echo TEXT_YOUR_IP_ADDRESS . ' ' . $_SERVER['REMOTE_ADDR']; ?></div>
<!--eof-ip address display -->
<!--bof-banner #5 display -->
if (SHOW_BANNERS_GROUP_SET5 != '' && $banner = zen_banner_exists('dynamic', SHOW_BANNERS_GROUP_SET5)) {
<div id="bannerFive" class="banners"><?php echo zen_display_banner('static', $banner); ?></div>
<!--eof-banner #5 display -->
<!--bof- site copyright display -->
<div id="siteinfoLegal" class="legalCopyright"><?php echo FOOTER_TEXT_BODY; ?>
<?php if ($_GET['main_page'] == 'checkout_shipping' || $_GET['main_page'] == 'checkout') { ?>
<br />
<center>FedEx service marks used by permission.</center>
<?php } ?>
<!--eof- site copyright display -->
} // flag_disable_footer
The part in bold is the one I replaced like it said in the instructions. What did I do wrong?![]()
