Results 1 to 7 of 7
    Jan 2011
    Default Admin doesn't work using sub folder
    I am wanting to test Zencart but I do not have possession of the domain I will use. My idea was to install Zencart in a subfolder of my Wordpress site (www.mysite.com/testsite). When I go to that address it seems to work fine, but when I go to www.mysite.com/testsite/admin it pulls up my wordpress site and displays a page that doesn't exist. Any ideas?
    Feb 2005
    Lansing, Michigan USA
    Default Re: Admin doesn't work using sub folder
    How did you install Zencart ? Did you change the name of the 'admin' folder after installation ?
    Jan 2011
    I used cpanel (fantastico) to install it into a subfolder. I did not rename the admin folder. I also don't see an admin folder unless its in another folder.
    Feb 2005
    That's one of the problems with using an auto-installer. Zencart won't allow you to access the admin unless you change the admin folder name, so Fantastico must have done it for you. The renamed admin folder will be in the root of your store (www .mysite.com/testsite), so you'll need to check the folders there to find out which is admin, and point your browser there.
    Jan 2011
    Thanks Steve. I just figured that out and was about to come back on to say so. Fantastico did rename the admin folder. Everything seems to be working now.
    Jun 2005
    Cumbria, UK
    I think the default for fantastico is zc_admin.
    Please appreciate that this is still insecure. Hackers know that many people install with fantastico, and will try zc_admin.
    Best you re-name it to something less obvious.
    Bear in mind that you need to EDIT:
    zc_admin/includes/configure.php first, changing the name there too.
    After editing, you then re-name the folder.
    20 years a Zencart User
    Jan 2011
    Thanks for the info. I have indeed modified the configure.php file and changed the folder name. Things seem to be working great.
    Thanks again to everyone that helps on this board.
  1. v151 my function in folder extra_functions doesn't work
    By tips007 in forum General Questions
    Last Post: 23 Jan 2013, 02:53 PM
  2. v151 it doesn't work after I renamed admin folder name
    By limii in forum Basic Configuration
    Last Post: 14 Dec 2012, 08:16 AM
  3. Followed recommendations to rename admin folder - now doesn't work
    By alicia1234 in forum Installing on a Linux/Unix Server
    Last Post: 12 Aug 2011, 12:45 AM
  4. Moved Zen Cart into root folder.. Admin doesn't work!
    By chabates in forum Installing on a Linux/Unix Server
    Last Post: 4 Apr 2008, 05:39 PM
  5. Securing Image folder doesn't work right...
    By Karina_L in forum General Questions
    Last Post: 9 Oct 2006, 10:16 PM
