    Nov 2011
    Default [Not a ZC bug] Product attribute copy function resets sort order to 0
    ZC v1.3.9h
    When trying to use the copy function under the Option Value manager screen, the option values are copied but the pre-defined sort order for the option value is reset to 0 (not in the database but just in the product attributes).
    For Example:
    I have an option name: Color, option value: Red with sort order 15.
    I perform a copy to all products with the Color option, Red will show up under the product in Attributes Manager with sort order 0. If I delete Red from the options list, re-insert using the Attributes Manager, Red will show up correctly with sort order 15.
    Default Re: Product attribute copy function resets sort order to 0
    I cannot reproduce this issue ... do you have any add ons in your admin?
    Nov 2011
    Here is a list of the addons:
    Image Handler 3
    Attribute Rollover
    Return Authorization
    Order Delivery Date
    Master Password
    How did you hear about us
    Fed-Ex
    I'm guessing the first 2 maybe the culprit?
    That is possible ...
    First I would check that the file:
    /your_secret_admin/attributes_controller.php
    is the same file that comes with Zen Cart v1.3.9 ... and if different, it has been merged properly with any code changes ...
  1. Column Layout Grid for Product Listing > Sort order bug
    By edwardtilbury in forum All Other Contributions/Addons
    Last Post: 14 Mar 2009, 04:59 AM
  2. Attribute copy function not working
    By mka0202 in forum General Questions
    Last Post: 24 Sep 2007, 06:33 PM
  3. [Not a bug] Date Available Changed During Product Copy
    By bobguindon in forum Bug Reports
    Last Post: 6 Apr 2007, 09:20 PM
