Results 1 to 3 of 3
    Jan 2011
    Default Why Can Not Create Categories/Products?
    I am a 1.3.9 user and I just did a new install of 1.5.0 on another domain.
    There is not a "New Category" button. Am I missing something here? Is there a new way to add categories/products?
    Here is a link to the image
    http://screencast.com/t/mb0UEzqv
    Also, I see that the text editor is only Plain Text. Do you need a plugin now for an HTML editor?
    Thank you for any help you can provide.
    Brian
    May 2010
    WA State
    Default Re: Why Can Not Create Categories/Products?
    Categories and products are added in the same way in 1.50 as they are in 1.39. The fact that the new category button isn't appearing indicates that something got screwed up during the install. Perhaps a file or two got corrupted during FTP'ing.
    I believe that the answer is yes, you need to install an add-on for html editor.
    1. Your PHP files are damaged. You're encountering a PHP error which is resulting in a program halt, which delivers the symptom of a blank page, or in your case a partial blank page. It's the most common problem. See here: https://www.zen-cart.com/tutorials/index.php?article=82
    2. If you want an HTML editor, you can install a plugin for it.
  1. why can not me create a ez page?
    By linjuming in forum General Questions
    Last Post: 12 Oct 2012, 04:31 AM
  2. Why are my default categories and products not showing?
    By prakashjan in forum Templates, Stylesheets, Page Layout
    Last Post: 13 Feb 2010, 06:22 PM
  3. Why Can't I Use Products and Categories Together?
    By limelites in forum Setting Up Categories, Products, Attributes
    Last Post: 21 Aug 2009, 03:12 AM
  4. Replies: 0
    Last Post: 12 Dec 2007, 04:01 AM
