DrByte
Somehow your database has been changed and a required column/field is missing from the admin table.
You need to find out why that is.
A fresh clean install of Zen Cart v1.3.9h does indeed contain the admin_level column. So, either you've done something yourself which has deleted that column, or you've installed an addon that's deleted it, or you've been hacked by someone who's deleted it.
If indeed you've done NOTHING to change the initial install of Zen Cart on your site, then perhaps a fresh new install after wiping all the files and deleting and recreating the database would be your smartest first step. And while you're at it you may as well use the latest version of Zen Cart. No point starting a new site on old code.
