Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Default Re: Need Help ~ Admin Settings
    Did you do an upgrade to 1.5.0 at all?
    I say that because only the v1.5.0 upgrade would ever delete the admin_level field. Unless you're mucking around with addons which compromise the functionality of your store.
  2. #22
    Yes, it was upgraded and then we went back to the 1.3.9h because there were add-ons that I needed but don't yet work with 1.5. What would you suggest be done to fix the issue? Thanks in advance for your help, its much appreciated.
  3. #23
    You can't just "go back", without undoing the several hundred database changes that were done during the upgrade. You should have restored from backup, not just changed the PHP files.
    I suspect there are numerous other additional problems you've not seen yet that will come up and bite you in the arse if you continue using old software with the newer database. You really ought to push forward to your upgraded site ASAP.
  4. #24
    A restore was performed, but something went wrong. Thanks for your help.
  1. Need help with main page settings
    By Dashizna in forum Basic Configuration
    Last Post: 3 Dec 2011, 07:28 PM
  2. Need help with Attribute Settings
    By nrg77 in forum Setting Up Categories, Products, Attributes
    Last Post: 9 Jul 2007, 06:12 AM
  3. Settings for shipping - need help
    By blindman in forum Currencies & Sales Taxes, VAT, GST, etc.
    Last Post: 7 Aug 2006, 01:16 AM
  4. Table Rate settings: In need of help!
    By dori in forum Addon Shipping Modules
    Last Post: 20 Jul 2006, 06:31 AM
