    Feb 2009
    help question Help with a little bit of PHP coding for discounting ....
    I have a module that was built where if multiples of 3 are put into the cart then, one of the products is free.
    Today, I modified the code so that the first product would be £5.99 then every product after would be discounted by £3.49. The problem is that for every multiple of two products that are added £3.49 is deducted!
    I'm sure it should be a simple coding fix? I would really appreciate it if someone could take a minute to have a look at the relevant bit and tell me what I need to change. Please. :)
    Here's the code:
    		$disc_amount += $this->get_disc_amount($all_items, $price);
           $this->explanation = YOUR_CURRENT_3_FOR_2_DISCOUNT_CONFETTI . "\\n" . "\\n";
           $this->explanation .= "\\n\\n" . TOTAL_DISCOUNT . $this->print_amount($disc_amount);
    	   $od_amount['total'] = round($disc_amount, 2);
           return $od_amount;
       function get_disc_amount($count,$price) {
          $disc_amount = 0;
    	  $new_count = $count - ($count%2);
    //	  if (($count % 2) == 0) {
    	  	$disc_amount = ($new_count/2) * 3.49;
          return $disc_amount;
    Many thanks,
    Gary
    Feb 2009
    Default Re: Help with a little bit of PHP coding for discounting ....
    Can anyone help, please? :)
    Jan 2012
    I'm not 100% sure what you are asking for, but this should work. I read it that you didn't want the multiples of 3 thing any more, just deduct 3.49 from each if ordering more than 1 (excluding the first).
    $disc_amount = ($count 1)* 3.49;
    return
    $disc_amount
    Feb 2009
    That worked perfectly. Thanks very much. :)
  1. v151 need help to find a little bit of code.
    By Nixe in forum General Questions
    Last Post: 19 Mar 2013, 01:58 PM
  2. Replies: 7
    Last Post: 4 Aug 2009, 12:53 PM
  3. Help with a bit of coding! Alternative to creating drop-down list
    By teaj in forum Templates, Stylesheets, Page Layout
    Last Post: 5 May 2009, 12:25 PM
  4. A little help with some coding required!
    By Still Crazy in forum General Questions
    Last Post: 12 Apr 2007, 06:13 AM
