Results 1 to 10 of 20
    Mar 2009
    Default Negative values in order total. Edit Orders Problem
    In orders_total the ot_group_pricing class shows values as positive, this results in the wrong values being shown in edit orders.
    Can someone write me some sql code that will enable me to change all positive 'value' where 'class' = ot_group_pricing in orders_total as doing 898 one by one would be just too much!
    Mar 2009
    Is it possible to modify the code so that any negative values, i.e. group pricing or reward points are stored as negative values in the ordertotals database table?
    Feb 2006
    Tampa Bay, Florida
    Default Re: Negative values in order total
    You're going to have to do a database query to fix the values you already have. If someone doesn't post it before I get home I'll post it then.
    For the code change to prevent future problems, here are the instructions.
    http://thecartblog.com/2009/12/21/ze...counting-mods/
    I notice that Edit Orders 3.0 has this problem partially fixed; I'll fix that at some point this month.
    Jun 2003
    Default Re: Negative values in order total. Edit Orders Problem
    Moderator's note: thread moved to the appropriate forum.
    Mar 2009
    I have latest version of edit orders.
    I use reward points and group discount, these need to be stored as negative values in the order_totals table so that my exporting of sales data is shown correctly
    Mar 2009
    This isn't an edit orders problem, as a fresh order stores the values as positive before I even look at the order. (checked in the database)
    Right. It's your order export routine which needs improvement.
    Zen Cart's architecture stores the 'value' field without a minus sign, because it knows that the line item is a negative amount based on the order total module used for that line item.
    If you want to rewrite the core code to work entirely differently just so you don't need to change your export process, feel free.
    If you go changing existing data then all your order details will show up incorrectly for your customers and in your admin panel.
    Maybe you should change your export approach?
  1. Replies: 2
    Last Post: 8 Apr 2015, 01:23 PM
  2. v139h Edit Order Total Headings
    By SethF in forum Templates, Stylesheets, Page Layout
    Last Post: 8 Apr 2012, 09:02 PM
  3. Replies: 2
    Last Post: 23 Jul 2009, 12:59 AM
  4. Edit Order drops tax of sub total?
    By Gonzon in forum All Other Contributions/Addons
    Last Post: 14 Jan 2008, 12:24 PM
  5. Table Rate Calculation Problems with Negative values
    By matt123 in forum Built-in Shipping and Payment Modules
    Last Post: 15 Dec 2007, 06:28 AM
