Results 1 to 9 of 9
    Jan 2010
    Default Different Prod info pages for differnt products?
    Hello
    i have a nice product info page which suits 80% of my products.
    For the other 20% id like to make a different layout.
    A smaller image size, more room for text and some other layout changes.
    Is this possible?
    Regards
    Cookie
    Default Re: Different Prod info pages for differnt products?
    Anything is possible, it just depends on exactly what you want for how difficult/easy it will be.
    If all of your 20% products are in one or more separate categories, you could probably set up per-category stylesheets to override standard CSS rules. If you have a small/manageable number of different products, you could make a per-product stylesheet and copy it for each relevant product id.
    If your desired changes are not susceptible to CSS solutions, or are scattered among different categories, you might need to create a new product type to have its own tpl_product_special_info_display.php and other files.
    Jan 2010
    Thanks Gjh42
    i think your approach above might work.
    Could you give me few tips?
    Thanks again
    Cookie
    Read the CSS-readme.txt in /includes/templates/template_default/css/ for a summary.
    Make a stylesheet file with just the rules you need to be different from standard, and name it according to the category id or cPath, like c_23.css. You will need a copy of the same file named for each category.
    For the rules you need, I would have to see what you have (live, not a screenshot) and what you want.
    Jan 2010
    Thanks again
    i have a working knowledge of CSS
    And the product id like to have a different prod page are all in the same category.
    But were im stuck is how do i make those different products display the new CSS
    instead of the current CSS file im using for all the other prod info pages.
    if im making sense - i hope
    Regards
    Cookie
    Did you read the readme file I told you about? Saving a file with the correct name will cause it to automatically load for the desired category (or other page type).
    Jan 2010
    O Great
    Nice one!
    Jan 2010
    I dont think CSS alone is gonna do it.
    would there be a way to just reduce the image size displayed on the prod info page -
    But only for products in a particular category?
    Cookie
    If you are depending on the medium image size setting to scale your images down, you are doing it wrong. You should save your medium images at the exact pixel size you want them to display so the browser doesn't have to do a quick & dirty resizing on the fly. If you save this category's medium images at the smaller size, that is how they will display. If you need to reduce the space reserved for these smaller images, you can do that with a per-category stylesheet, using !important if necessary in the width declaration to override the inline styling.
  1. v150 different product info pages for different categories
    By twistedmilas89 in forum Templates, Stylesheets, Page Layout
    Last Post: 12 Jul 2012, 09:10 PM
  2. Different product info pages for products
    By longstockings in forum General Questions
    Last Post: 11 Jan 2012, 11:04 AM
  3. Different Images for Cart vs. Prod Info
    By realeyz in forum Templates, Stylesheets, Page Layout
    Last Post: 2 Nov 2009, 09:19 PM
  4. Configuring different shipping mods for differnt products?
    By bgroup99 in forum Built-in Shipping and Payment Modules
    Last Post: 17 Dec 2007, 05:00 AM
  5. Differnt stores for different domains & Dreamhost.com
    By jdesson in forum Templates, Stylesheets, Page Layout
    Last Post: 6 Jun 2006, 09:00 PM
