Results 1 to 7 of 7
    Aug 2007
    Manitou Beach, Michigan
    Default DB/SQL Error when using SQL Patch for Add Pages More Info Sidebox addon
    Hi, I am getting this error when I try to add the SQL patch to the Add Pages to More Info Sidebox add on.
    Have you already posted about this issue? If so, DO NOT POST a duplicate. Instead, reply to your existing post, with MORE information.
    No
    What version of Zen Cart are you using?
    139h
    Has your site been upgraded? When? From what version(s)?
    NO
    If you've upgraded, HOW did you upgrade? (official upgrade procedure or an automated script from your hosting company?)
    N/A
    What addons have you installed? When?
    add_pages_to_more_information_sidebox_2
    add_customers_from_admin_1-07
    events_calendar_1-02
    backup_mysql_plugin_1-5
    easy_populate_csv_1-2-5-7b
    facebook_sidebox_1-0
    twist_of_nature_1-01 ----- template being used....
    Master Password
    HOW did you install it? (upload via FTP and run zc_install, or a one-click install from your hosting company? (one-click installs are NOT recommended))
    In what ways is your site customized or different from a brand new uncustomized install?
    jz_silver_wide template being used and some text changes.
    If you're encountering display/layout problems, post your site URL* so it can be seen in action.
    N/A.
    If you're encountering problems that could be related to your server or hosting company, include the name of your hosting company (not their URL).
    IX Webhosting
    HAVE YOU LOOKED IN THE FAQ AREA for answers to your question? (ie: a search for your error message or what you want to edit/change, etc)
    Yes
    Have you searched the FORUM for your error message or for answers to the question you're asking?
    Yes
    WHEN did the problem "start"? How does that compare with other events of your hosting company, changes you've made to your site files/addons, or your admin settings, etc?
    Since Add on added too
    If this is your first store, have you tested all aspects of transactions before going live?
    No
    This is the error I get.
    1062 Duplicate entry 'DEFINE_PAGE_5_STATUS' for key 2
    in:
    [INSERT INTO configuration (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, last_modified, date_added, use_function, set_function) values ('Define Page 5', 'DEFINE_PAGE_5_STATUS', '1', 'Enable the Defined Page 5 Link/Text?
    0= Link ON, Define Text OFF
    1= Link ON, Define Text ON
    2= Link OFF, Define Text ON
    3= Link OFF, Define Text OFF', '25', '85', now(), now(), NULL, 'zen_cfg_select_option(array(\'0\', \'1\', \'2\', \'3\'),');]
    Do I need to do something with my DB?
    Mark
    Default Re: DB/SQL Error when using SQL Patch for Add Pages More Info Sidebox addon
    "duplicate entry" indicates you've already got the entry in your database.
    Without studying ALL the sql statements that your addon requires and comparing that against your live database, I can't tell you whether there are still steps that need to be run or not. But the error message certainly reveals that the entry that the script is trying to insert is already there. There may be more that haven't been entered but need to be.
    You'll need to get down and dirty with checking every entry in your database against what that script is trying to do.
    Aug 2007
    Hi Doc,
    Thanks for the quick reply. I will do some digging into the DB and see what I come up with.
    Aug 2007
    HI,
    In looking at the DB in the tables I do have this entry for page 5,6 & 7. Should I remove the entries from the table and retry the SQL patch?
    Mark
    Aug 2007
    Well I removed the entries from the table and re-ran the SQL patch and got no error. But the side box still only shows page 2, 3 and 4 only not page 5, 6, or 7.
    ???? Something I missed? This add on has always worked in the past.
    Mark
    I suspect user error -- don't you need to turn on those links in Admin->Configuration->Define Pages?
    Or maybe you've got modifications to the original sidebox php file that are conflicting with that addon? ie: the code doesn't have the logic in it to display the links you've added and enabled.
    These are all questions suitable for posting in that addon's support thread.
    Aug 2007
    I got it working. I checked and all pages were turned on (1) in Admin->config>Define page status.
    Went back and reinstalled each step again after SQL patch and now all the pages are showing.
    Thanks for the sounding board.
    Mark
  1. Un-do SQL Patch for MAP Pricing addon?
    By Johnnycopilot in forum All Other Contributions/Addons
    Last Post: 14 Apr 2012, 08:19 AM
  2. Add Pages to More Info Sidebox addon question
    By Maynards in forum Templates, Stylesheets, Page Layout
    Last Post: 12 May 2010, 08:32 PM
  3. Error on install of a .sql for googleanalytics addon
    By EZorb in forum General Questions
    Last Post: 12 May 2010, 09:47 AM
  4. Error when using the SQL patch section.
    By arcanesanctuary in forum General Questions
    Last Post: 10 Oct 2009, 03:45 AM
  5. Quick Updates addon gives SQL error after uploading 20K product using Easy Populate
    By guzzer in forum Setting Up Categories, Products, Attributes
    Last Post: 22 Aug 2009, 03:11 PM
