I have a client that has a ton of blog reviews about a product at tons of urls and each was written by the blog owner.
The built it review section seems so limited when there is this vast amount of info out their to use.
What I have to work with is just a link to each blog post.
Do I write a plugin to take the link and then go out and parse the post and store the data?
Once having the info where do you display it, in the product, sidebox, menu?
Is there a plugin that is close to what is needed?
Comments suggestions needed.
Skip
