Results 1 to 10 of 19
    Feb 2012
    Default Column Layout Grid v1.3.8 Problem with first row
    I was having an issue with the Column Layout Grid add-on in that it would always drop the last object under the row. No matter how many columns I tell ZenCart I want, it does this. If I say 4 columns, then the first three columns show, and the object in the 4th shows up in a second row (and empty space where the 4th column should be). I see other people had this problem in the past.
    I read here http://www.zen-cart.com/showthread.p...isting-1-3-0-2 where Dr. Byte suggested:
    "making two small edits to the customized product_listing.php module used in the grid-layout mod: Basically, just subtracting 0.5% from the width of each cell, causing FF to render more consistently."
    Since my version of Column Layout Grid already was subtracting 0.5%, I changed it back to 1%. That fixed it for all of the rows except for the very first row. It looks differently than the other rows as well. In the first row, the product images and links are all centered. In the other rows, they are right-justified. In the first row, the product name is in bold and underlined. In the other rows, the product names look different. So there must be some specific code for just the first row.
    How do I change the first row to match the other rows?
    Feb 2012
    Default Re: Column Layout Grid v1.3.8 Problem with first row
    I have been viewing the source code and I think it has something to do with the first row as being listed as a table heading instead of table data. It does this when it displays search results as well. How do make it uniform?
    Dec 2010
    UK
    Quote Originally Posted by AvaAdorn View Post
    Any helpers will need a link to the problem page please.
    Jun 2005
    Cumbria, UK
    Try this. it MIGHT work
    Edit the following MODULE file:
    includes/modules/YOUR-TEMPLATE/product_listing.php
    FIND
      $column 0;
      if (
    PRODUCT_LISTING_LAYOUT_STYLE == 'columns') {
        if (
    $num_products_count PRODUCT_LISTING_COLUMNS_PER_ROW || PRODUCT_LISTING_COLUMNS_PER_ROW == ) {
    $col_width floor(100/$num_products_count) - 0.5;
        } else {
    $col_width floor(100/PRODUCT_LISTING_COLUMNS_PER_ROW) - 0.5;
    CHANGE TO
      $column 0;
      if (
        if (
    $col_width floor(100/$num_products_count) - 1;
        } else {
    $col_width floor(100/PRODUCT_LISTING_COLUMNS_PER_ROW) - 1;
    You may ALSO need to remove excessive PADDING, MARGIN or BORDER widths in any stylesheet declarations that affect those elements.
    20 years a Zencart User
    Jun 2005
    Cumbria, UK
    Better upgrade too... Your site is a hack waiting to happen.
    Feb 2012
    Thanks for the advice, schoolboy. I made that change from 0.5 to 1 before posting my question and it did work for all rows but the very first row. The problem is that the first row of products takes on the properties of what used to be the header row when my products were listed in rows instead of columns. If I remove the header row, it removes the first row of products in my case. How can I change the properties of the header row to match the other rows?
    For reference, you can see what I'm talking about here: http://www.avaadorn.com/dresses-c-3.html
    It is the same for any of my product listings/category pages.
    Jun 2005
    Cumbria, UK
    Your MAIN PROBLEM with styling is that you are using a TemplateMonster template. These templates ride roughshod over core Zc behaviour, and the column grid module you are trying so hard to get right will NEVER behave the way it is supposed to because your TM template and its associated CSS will just not allow it.
    I cannot help you as I do not have 3 days to unpick that TM template to find out where it needs changing.
    Best bet is to DUMP the TM template and get one that is compatible with zencart.
    Feb 2012
    I worked on the stylesheet some more and was able to fix the problem. Thank you for your suggestions.
    Jun 2005
    Cumbria, UK
    Your page: http://www.avaadorn.com/dresses-c-3.html is still showing the grid jumping to the next line. I am seeing TWO in a row, then ONE, the TWO in a row, then ONE MORE...
    the problem is the TABLE STRUCTURE forced into the TM template - a structure that DOES NOT EXIST in standard zencart.
    Feb 2012
    Thanks for pointing that out. I was only testing in Chrome and Safari, and it shows up perfectly in those browsers. In Firefox and IE, the grid jumps to the next line.
  1. Problem with Column Grid Layout in 1.3.5 - Please Help!
    By reddog73 in forum Templates, Stylesheets, Page Layout
    Last Post: 1 Sep 2010, 06:30 PM
  2. Problem with Column Layout Grid for Product Listing
    By maeve100 in forum Templates, Stylesheets, Page Layout
    Last Post: 17 Aug 2009, 04:02 PM
  3. Problem with column layout grid
    By erezw in forum Templates, Stylesheets, Page Layout
    Last Post: 14 Nov 2008, 10:35 PM
  4. Column grid layout and problem with IE7
    By Don_Makaveli in forum Templates, Stylesheets, Page Layout
    Last Post: 10 Nov 2008, 08:12 PM
  5. Column Layout Grid for Product Listing - Need Row Header
    By kwright in forum All Other Contributions/Addons
    Last Post: 16 Oct 2008, 09:36 PM
