Results 1 to 3 of 3
    Sep 2012
    New York, New York, United States
    cart error Problem with Related Products Addon
    I downloaded and installed the related products add-on, installed the .sql file and uploaded all the files. I even pasted the code on the product display page. I did not delete the existing (customers also bought code).
    I can't for the life of me figure out where to add these related products. Is it not installed properly, should there be a button in the menu or on the product page itself. Please help....
    There is no info on this plugin anywhere. Only how to install but not how to use.
    Thanks in Advance
    Craig
    Feb 2005
    Lansing, Michigan USA
    Default Re: Problem with Related Products Addon
    Since that mod was written for Zencart version 1.3.8 and has an admin component it's likely it won't work with version 1.5 without being updated.
    Sep 2012
    Is there an update? Probably not. I will contact the creator.
    Do you recommend any other add-ons for this? I downloaded cross-sell but I'm afraid to try to install it. There are so many files.
    Thanks for your quick response.
  1. Search products with related color
    By ian_xtian123 in forum All Other Contributions/Addons
    Last Post: 21 Dec 2012, 05:31 AM
  2. v139h problem with compare products addon
    By matelots in forum All Other Contributions/Addons
    Last Post: 5 Feb 2012, 07:56 PM
  3. MySQL Problem with Product with Attribute Stock addon
    By rtwingfield in forum All Other Contributions/Addons
    Last Post: 20 Sep 2011, 03:35 PM
  4. Help with adding related products
    By ricangem in forum Setting Up Categories, Products, Attributes
    Last Post: 17 Apr 2011, 06:49 PM
  5. Problem with 1.3.5 : security clearance - is it related to the upgrade?
    By sanji in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 17 Sep 2006, 12:26 AM
