Results 1 to 10 of 11
    Mar 2010
    Default Featured Products Box - Adding Space in between products
    I'm having trouble locating the CSS code I need to edit to add more space in between my products. If you look at my main page: http://www.soullow.com The products are way to close. This started after I increased the small image sizes.
    I'm also having the same kind of problems on my All Products page: http://soullow.com/store/index.php?m...e=products_all
    Thanks in advance!
    May 2011
    Default Re: Featured Products Box - Adding Space in between products
    Your css file is located at /includes/templates/theme488/css/stylesheet.css
    Mar 2010
    I know but I looked thru the style sheet and could not find which lines to change. Do you know what I mean?
    May 2011
    You can try to edit the .centerColumn {} in stylesheet_main.css
    Looking for lines in the stylesheet to change is the wrong approach.
    Look at the HTML output, either the "view source" or using a tool like Firefox Web Developer or Firebug, and find the classes, ids or other elements that control the styling. Test changes using those tools (you can add new rules as well as modifying existing ones) and when you find what works, add the changes to the stylesheet.
    Many CSS ids and classes exist in the code but are not mentioned in the stylesheet; they are there for convenient use if someone needs them.
    Mar 2010
    I've tried using firebug and that approach has not been very helpful so far....
  1. Featured Products Box - Adding Space Above...
    By stiggy100 in forum Templates, Stylesheets, Page Layout
    Last Post: 26 May 2009, 02:37 AM
  2. Blank selection box for adding featured products
    By artcoder in forum Templates, Stylesheets, Page Layout
    Last Post: 19 Feb 2009, 05:09 AM
  3. Adding a Latest Products/Featured Products box
    By paulograngier in forum Templates, Stylesheets, Page Layout
    Last Post: 9 Feb 2008, 02:01 AM
  4. adding space between products
    By recordshow in forum Templates, Stylesheets, Page Layout
    Last Post: 5 Dec 2006, 09:18 AM
