Results 1 to 10 of 10
    May 2012
    Default eProcessing Network - emulator problem
    I have a new implementation of Zen Cart 1.5 and I am using eProcessingNetwork for processing payments, using SIM not AIM.
    When a transaction is done, I receive the payment via eProcessingNetwork and the client receives an email confirming payment (but no email from ZenCart with order details). So far all is good. I have two problems :
    1. Next page the client get is a list of my categories with Page Not Found at the top, and the following URL in the address bar :
    https://www.eprocessingnetwork.com/cgi-bin/an/order.pl
    2. I dont receive order details, Admin > Customers > Orders has no record of the transaction. So i have no idea what to ship the client, indeed if if want for the payment in eProcessingNetwork I would have no record of the transaction.
    Any idea what I have done wrong??
    Default Re: Eprocessingnetwork issues
    Quote Originally Posted by Darren Cubi View Post
    (I cant setup AIM it has an error that it requires Admin configured for SSL but the error is on an https page... but thats not what I am trying to solve).
    That's because you need to set the HTTP_SERVER value in your admin configure.php to an https URL.
    I suspect you've given an invalid return page address in your gateway setup. That's something the SIM approach relies upon heavily, but which the AIM approach doesn't require.
    Perhaps consult http://www.zen-cart.com/content.php?...payment-module
    That's because of the problem above. If it doesn't return to a suitable page so that checkout processing can complete on your store, then there will certainly be no order recorded in your store and no emails sent from your store.
    I'm having trouble understanding what you were trying to say there. Seems like three disjointed thoughts.
    Apr 2008
    I suspect you've given an invalid return page address in your gateway setup. That's something the SIM approach relies upon heavily, but which the AIM approach doesn't require. Perhaps consult http://www.zen-cart.com/content.php?...payment-module. . . . If it doesn't return to a suitable page so that checkout processing can complete on your store, then there will certainly be no order recorded in your store and no emails sent from your store.
    Was this issue ever resolved? I am having this same issue with the transaction successfully processed but it does not return to the checkout process. Where is the return page address recorded? Is it in one of the data fields submitted to eProcessng? Are these fields correct?
    'x_relay_response' => 'TRUE',
    'x_relay_URL' => zen_href_link(FILENAME_CHECKOUT_PROCESS, 'action=confirm', 'SSL', true, false),
    'x_receipt_link_method' => 'POST',
    'x_receipt_link_text' => 'Click here to complete your order.',
    'x_receipt_link_url' => zen_href_link(FILENAME_CHECKOUT_PROCESS, '', 'SSL', false)
    Any information you can provide would be most helpful. Thank you.
    Quote Originally Posted by lhollo View Post
    The relay/receipt URLs coded into the SIM module code are correct as far as the module goes.
    Any problems with properly returning will be a consequence of misconfiguration in your eprocessing account settings.
    Sep 2012
    Default Eprocessing Network Setup
    I have Eprocessing Network already setup and would like to know how to integrate it onto ZC. I am using ZC 1.5.0.
    Mark
    Default Re: Eprocessing Network Setup
    You will have to ask them if they have a module or what common module can be used in place of
    Sep 2012
    I did and they told me to ask Zen Cart.
    There currently no plugin for "Eprocessing"
    They should know and assist with what it takes to access their gateway
    Quote Originally Posted by firstcapitalfirearms View Post
    Mark
    I have been at this for a few days now with no luck. I realize "there is currently no plugin for "Eprocessing", however I have seen several posts (here is one of the originals) instructing us to use Authorize.net emulation using AIM. This feature is "built in" to the eProcessing gateway feature. There have apparently been several people that have gotten AIM to work, but what about SIM? Currently I do not have an SSL which is the only reason I have chosen to use SIM. Apparently AIM runs smoother than SIM, so if it comes down to it, I may just have to bite the SSL bullet.
    I am currently using ZC 1.5. and have followed all of the steps of those before me to no avail, replacing the URL's gets part of the problem resolved but not all of it.
    Upon checkout after I reach the gateay page and enter all customer address and cc info, I am returned to my site with a big 404 error. Since eProcessing sees the transaction reject (using psuedo cc info), they say this is a coding issue on Zencart and they cannot assist (obviously). I spoke with 3 different individuals and each say the same thing.
    During the checkout process when I reach the gateway and submit all of the financial info, it appears Zencart isn't getting the formatted response it needs from eProcessing to process the order, so when I refresh the screen and pull up my shopping cart the items are still in it and there are no pending orders in my admin panel. eProcessing says it is the return URL that is failing which they say is in the Zencart coding. This is where I get lost.... If there is anything that anyone can suggest then please reply. I'm 99% sure this is a noob issue on my end...
    Quote Originally Posted by godfogger View Post
    What's the URL in the browser address bar when you get that 404 error?
    Is it saying a 404 error, or is it a 406 error? Is it a blank page?
  1. v151 eProcessing Network Changes
    By ShannonWatts in forum Addon Payment Modules
    Last Post: 11 Jun 2015, 02:29 AM
  2. v150 eProcessing Network Integration - redux
    By Jeff Ski Kinsey in forum Addon Payment Modules
    Last Post: 18 Mar 2013, 03:53 PM
  3. v151 Whoops Your Session Has Expired when using eProcessing Network SIM emulator
    By firstcapitalfirearms in forum General Questions
    Last Post: 22 Feb 2013, 07:23 PM
  4. Problem with eProcessing Network
    By akincer in forum Addon Payment Modules
    Last Post: 5 Apr 2011, 04:43 AM
  5. eProcessing Network Integration
    By jacdesigner in forum Addon Payment Modules
    Last Post: 25 Nov 2009, 06:25 AM
