Results 1 to 3 of 3
    application error problem with cURL on WAMP
    I'm trying to install zencart on a WAMP (Apache 2.4.2, MySQL 5.5.24, PHP 5.4.3) setup on W7.
    However, The setup inspection screen is telling me that cURL support = OFF, yet my php.ini is showing it as ON (as does the drop-down list from the WAMP system-tray function. Can anyone shed any light on this situation please?
    Steve R
    Default Re: problem with cURL on WAMP
    The System Inspection screen gets its info by asking PHP what the status is for each of those things.
    In this case, Zen Cart is asking PHP whether the 'curl' extension has been loaded. And PHP is not saying yes back.
    Feb 2012
    mostly harmless
    Default Re: problem with cURL on install
    Quote Originally Posted by Porpoise View Post
    ... The setup inspection screen is telling me that cURL support = OFF, yet my php.ini is showing it as ON (as does the drop-down list from the WAMP system-tray function.
    Do a quick double check. If you go to http://localhost/?phpinfo=1 on the computer with WAMP installed, does this page say cURL support is enabled? I seem to remember in the past having some issues using WAMP related to me not modifying the correct "php.ini".
    While probably not the problem, you will also want to make sure both the apache and php executable you are using are added as exceptions to any installed firewall (even the built in Windows Firewall) and can communicate with the outside world (you could temporarily disable any firewalls to see if this is the problem).
  1. Problem With cURL on XAMPP and Windows 7
    By Grumpy One in forum Installing on a Windows Server
    Last Post: 22 Sep 2011, 12:14 PM
  2. Install problem - wamp 2.0
    By BigMike57 in forum Installing on a Windows Server
    Last Post: 22 Nov 2009, 12:35 AM
  3. Wamp wamp wamp - can't get wamp to run
    By mw4kids in forum Installing on a Windows Server
    Last Post: 21 May 2009, 03:37 AM
  4. Wamp and zen cart = CURL error!
    By johnylee in forum Installing on a Windows Server
    Last Post: 20 Mar 2009, 10:12 PM
  5. Problem with cURL
    By Macbos in forum Built-in Shipping and Payment Modules
    Last Post: 9 Nov 2006, 05:01 PM
