Results 1 to 8 of 8
    Aug 2009
    Bedford, England
    Default PayPal Website Payments Standard - Problem with product names
    I have PayPal Website Payments Standard - IPN enabled.
    ZC version 1.3.9h
    I have the show item lines in PayPal enabled.
    When directed to PayPal, The item titles are showing the Attribute Name and option instead of the Product name??
    Is this normal or is something wrong here?
    Phil
    Phil Rogers
    A problem shared is a problem solved.
    Default Re: PayPal Website Payments Standard - Problem with product names
    Not sure with IPN
    But you should switch to the more robust and stable PayPalExpress module
    Aug 2009
    Bedford, England
    It's only when there is an attribute assigned. Working otherwise.
    Surely it's just calling the wrong info? Or maybe it's calling both and there is a character limit on PayPal?
    Phil Rogers
    Enable paypal logging in the admin setup
    Make a couple of test purchases and check the logs
    Post them here if you need assistance figuring them out
    Aug 2009
    Bedford, England
    Ok cool will do, I'll have a look at the source code in the confirmation page too, hopefully should see the PayPal HTML form markup on there?
    Phil Rogers
    Aug 2009
    Bedford, England
    think I have fixed it, though if someone can check the change I have made and let me know if there is any reason this will casue any problems.
    In /includes/modules/payment/paypal/paypal_functions.php
    I found this code:
          // if there are attributes, loop thru them and add to description
    if (isset($order->products[$i]['attributes']) && sizeof($order->products[$i]['attributes']) > ) {
    $optionsLI["item_name_$k"] = '';
            for (
    $j=0$n2=sizeof($order->products[$i]['attributes']); $j<$n2$j++) {
    $optionsLI["item_name_$k"] .= "\n " $order->products[$i]['attributes'][$j]['option'] .
    ': ' $order->products[$i]['attributes'][$j]['value'];
    // end loop
    // endif attribute-info
    notice how the $optionsLI["item_name_$k"] = ''; is blank and not redefined anywhere after?
    so I changed to this:
    // $optionsLI["item_name_$k"] = '';
    $optionsLI["item_name_$k"] = $order->products[$i]['name'];
            for (
    // $optionsLI["item_name_$k"] .= "\n " . $order->products[$i]['attributes'][$j]['option'] .
              //                              ': ' . $order->products[$i]['attributes'][$j]['value'];
    $optionsLI["item_name_$k"] .= ': ' $order->products[$i]['attributes'][$j]['value'];
    // end loop
    Look forward to hearing back, cheers
    Phil
    Phil Rogers
    Based on what you said you wanted it to differently, yes that should work.
    Aug 2009
    Bedford, England
    Doc, so is it normal behaviour that when there are options that it only uses the option name and value as the item title? That's what the original code seems to be doing?
    Glad what I've done is ok :)
    Phil Rogers
  1. PayPal Website Payments Standard - IPN issue with questionable address
    By Wicked-Incense in forum Built-in Shipping and Payment Modules
    Last Post: 15 Dec 2011, 09:03 AM
  2. No unit price with Paypal IPN - Website Payments Standard
    By mwilliams in forum Built-in Shipping and Payment Modules
    Last Post: 26 Oct 2010, 10:21 AM
  3. Customers entering info twice with PayPal Website Payments Standard?
    By Geoff2727 in forum Built-in Shipping and Payment Modules
    Last Post: 22 Dec 2009, 02:54 PM
  4. PayPal IPN - Website Payments Standard Setting Problem
    By miles in forum Built-in Shipping and Payment Modules
    Last Post: 15 Sep 2009, 06:36 AM
  5. Replies: 1
    Last Post: 16 Feb 2009, 11:52 AM
