Results 1 to 10 of 32
    Dec 2010
    Default Problem Downloading products whose filename starts with #
    We're having a major issue here with customers trying to download purchased books, and getting error messages. When we had the books uploaded just as zip files, it worked fine. But now we've separated out all the file formats into epub, mobi, pdf, etc., and the books won't download.
    This is the error message we're getting:
    Forbidden
    You don't have permission to access /zencart/pub/.xlfbvtmnxuexokrusgnn-1354130851/AustinSoutherly-ReclaimedLove.mobi on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
    I presume that the /.xlfbvtmnxuexokrusgnn-1354130851 is because it's creating a secured or hidden url so that the book url can't be passed around...but why is it not downloading properly when the Attributes are set up properly (green button)?
    Please help...we're hosting a really big-selling book for a friend as a favor, and the sales are coming through fast and hot...but the customers can't download their books, so we're having to manually send copies to each person, which does not reflect well.
    Thank you!!
    Default Re: Major Problem Downloading Purchased Books
    Check the .htaccess files for something similar to:
    <FilesMatch ".*\.(zip|ZIP|gzip|pdf|PDF|mp3|MP3|swf|SWF|wma|WMA|wmv|WMV|wav|epub)$">
    there should be 2 in there ... see if adding your file extension(s) help ...
    Feb 2012
    mostly harmless
    You probably need to adjust the .htaccess file in your "/pub" directory to allow files ending with "mobi". Handling for files ending with "mobi" are not included in the default installation.
    EDIT: Ajeh you are just too fast! ;)
    Dec 2010
    Lhungil, thank you for telling me where to find the correct version of .htaccess...I freaked when I looked at the one in the root directory and it was empty! LOL
    It says <FilesMatch ".*\.(zip|ZIP|gzip|pdf|PDF|mp3|MP3|swf|SWF|wma|WMA|wmv|WMV|wav|epub)$"> which I presume is the default setting. So I should just add |azw3|fb2|mobi| etc at the end of the line, before the end-parenthesis?
    Be aware that there should be two lines with the similar details on them and both need the new extension(s) added to them ...
    Dec 2010
    That did it...thank you both for your help!!!!!!!!!!!!!!!!!!!!!!!!!!! You guys ROCK!!!!!!!
    Thanks for the update that your downloads are working now that you adjusted the .htaccess file to work with your extension(s) ...
    Dec 2010
    I thought we had this problem licked, but it happened again today with a pdf file.
    Per your instructions a few days ago, I modified the .htaccess file in both places, and uploaded it...and just to be sure, I included both |pdf| and |PDF| in the lists of acceptable formats. I didn't know if it was case-specific, so better safe than sorry. I've also verified that the pdf actually exists on the server, it's properly attributed on the Attributes screen, all the capitalization is exactly the same on the file name and the Attribute, etc. And yet, when the customer tried to download the pdf file, she got the following error, just like what was happening before:
    Forbidden
    You don't have permission to access /zencart/pub/.psqpkszbvdmeoise-1354495264/ on this server.
    When I logged into her account using the Encrypted Master Password module, and tried to download it myself as a test, I got the same error.
    Is it significant that the file name is not included in the error message? I noticed that it was the other day, when this first happened. The file name is #13-BestBuddies-Sinh,Becca.pdf.
    I manually sent her a copy of the file, so the problem is solved for now...but I sure would like to figure out why this happened so that I can get it fixed before another person tries to order a book, and can't download it.
    Thanks very much for your advice on this, it's greatly appreciated!!
    You are using special characters other than alpha, number, dash and underscore ...
    Try changing the filename to not include the # and possibly the comma in the name ...
  1. Problem with downloading files after purchase
    By webmiss in forum Managing Customers and Orders
    Last Post: 7 Jan 2012, 09:09 PM
  2. Starts with wrong domain host name
    By meshgraphics in forum Installing on a Linux/Unix Server
    Last Post: 20 Aug 2010, 10:40 AM
  3. Html starts with blank rows
    By tslav in forum General Questions
    Last Post: 17 Sep 2008, 10:28 AM
  4. problem with illegal characters in image upload filename
    By rosenblum68 in forum Bug Reports
    Last Post: 9 Nov 2007, 05:02 PM
  5. Problem with Downloading items
    By GTB in forum General Questions
    Last Post: 12 Sep 2007, 06:52 AM
