Hello Everyone,
I'm getting a random issue the 'Starting at:' being calculated incorrectly. All of of my products are set to 'Priced by Attributes' with numerous options and options values all set to be "included in the base price" . My understanding is that Zen Cart should take the lowest price for of each option and add them up to calculate the 'Starting at:' price. Most of my products work exactly this way, however some just don't, an example is found here:
http://www.kcbgraphics.com/index.php?main_page=product_info&cPath=17_208_213&products_id=2060
The lowest price for this should be 'Starting at:$6.56' but instead it includes a $25.00 charge included under 'Is Design Required' for price of $31.56. If I set this option value to 'Not Included in Base Price' in the Attributes Controller it calculates correctly. If I compare this product to others that function correctly there appears to be no difference between their settings.
What's the best way to correct this glitch/anomaly?
Any help or comment would be appreciated. Thank you.
