Hi I recently upgraded to 1.5.1 and everything seemed to work fine for a few days until recently when I discovered I can no longer add new products to my site.
I was using apsona shop admin for a while but then it stopped working and was giving me an error about their being an error in an sql statement. I have written to apsona bug reports and they inform me they are unable to help me for a matter of weeks as they are busy. So I figured I would just start adding my products manually.
I click the add new product button and am able to enter all the product details and see the preview but when I click the insert button I get the following error "WARNING: An Error occurred, please refresh the page and try again."
I checked the logs and I can see the following error keeps appearing in the logs.
[05-Jan-2013 19:04:27 UTC] PHP Warning: require(DIR_WS_TEMPLATEStemplate_default/common/html_header.php) [<a href='function.require'>function.require</a>]: failed to open stream: No such file or directory in /home/lovelust/public_html/store/index.php on line 43
[05-Jan-2013 19:04:27 UTC] PHP Fatal error: require() [<a href='function.require'>function.require</a>]: Failed opening required 'DIR_WS_TEMPLATEStemplate_default/common/html_header.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/lovelust/public_html/store/index.php on line 43
So I started a search on this forum and google and found this error in various posts but none of the fixes seem to work for me. I have checked and double checked my configure.php files but cannot see where the problem is.
Here are the contents of my admin/includes/configure.php (sensitive info removed)
  //define('HTTP_SERVER', 'http://www.example.com');
  define('HTTP_SERVER', 'http://www.lovetolust.com');
  define('HTTPS_SERVER', 'https://enterprise.terrassl.net');
  define('HTTP_CATALOG_SERVER', 'http://www.lovetolust.com');
  define('HTTPS_CATALOG_SERVER', 'https://enterprise.terrassl.net');
  define('DIR_WS_ADMIN', '/store/myadmfolder/');
  define('DIR_WS_CATALOG', '/store/');
  define('DIR_WS_HTTPS_ADMIN', '/~lovelust/store/myadmfolder/');
  define('DIR_WS_HTTPS_CATALOG', '/~lovelust/store/');
  define('DIR_FS_ADMIN', '/home/lovelust/public_html/store/myadmfolder/');
  define('DIR_FS_CATALOG', '/home/lovelust/public_html/store/');
  define('DB_TYPE', 'mysql');
  define('DB_PREFIX', 'zen_');
  define('DB_SERVER_USERNAME', 'myusrname');
  define('DB_SERVER_PASSWORD', 'mypassword');
  define('DB_DATABASE', 'mydbname');
  define('USE_PCONNECT', 'false');
  define('STORE_SESSIONS', 'db');    define('DB_CHARSET', 'latin1');
  // for STORE_SESSIONS, use 'db' for best support, or '' for file-based storage
  // For SQL_CACHE_METHOD, you can select from:  none, database, or file
  // ie: /path/to/your/webspace/public_html/zen/cache   -- leave no trailing slash
  define('DIR_FS_SQL_CACHE', '/home/lovelust/public_html/store/cache');
// EOF
Here are the contents of my includes/configure.php (sensitive info removed)
  define('ENABLE_SSL', 'true');
  define('DIR_WS_PHPBB', '/');
  define('DB_SERVER_PASSWORD', 'mydbserver');
// EOF
I really don't understand what has happened, everything was working for a day or two after upgrading to 1.5.1 then suddenly this happens. Do you think it is a problem with my database?
I'd appreciate any assistance as I am fairly new to ZenCart and have tried solving this on my own to no avail.
